93 civic dx 4dr cyl#3 no spark or miss firing
Old Nov 7, 2011 | 04:59 AM
low13da9's Avatar
Default 93 civic dx 4dr cyl#3 no spark or miss firing
ok so i have a stock 93 civic 4dr dx,d15b7,cylinder #3 has no spark
i've changed wires,plugs,injectors,clips,and nothing,wtf is going on?need help.. EVERYTHING WORKS BUT ITS MISS FIRING,i grounded the plug wire and theres spark but its not doing anything in the cylinder??????????help
Old Nov 7, 2011 | 06:35 AM
low13da9's Avatar
Default Re: 93 civic dx 4dr cyl#3 no spark or miss firing
ANYONE PLZ
Old Nov 7, 2011 | 08:08 AM
HondaPartsHero's Avatar
Technical Hero
Does it have spark or not? Is the injector firing? Misfires can also be caused by low low cylinder compression.
Old Nov 7, 2011 | 10:43 AM
low13da9's Avatar
NO SPARK BUT SWAPPED OUT THE INJECTOR TO ANOTHER CYLINDER AND IT WORKED ON THE OTHER CYLINDER
Old Nov 7, 2011 | 03:36 PM
fcm's Avatar
fcm
Old Fart
Plug a spark plug into the spark plug lead and ground the plug and see if you get spark, if not the problem must be the spark plug lead, distributor cap or rotor, pull the cap and inspect inside of cap and rotor for carbon arcs. 94
Old Nov 7, 2011 | 07:25 PM
Siriuswerks
Guest
Posts: n/a
If you have the spark plug in the spark plug wire and you place it about 1/2 and inch away from the header, header bolts, valve cover bolts. Now do these to all of them and if you have spark missing on anyone of them take your distributor cap off. and post up a picture. Remember 3 things have to be on point Fuel, Ignition, and Timing
Old Nov 8, 2011 | 01:16 AM
Technical Hero
This is what I don't get. Sounds to me like its getting spark if you've tested it this way. How do you know its not getting spark "in the cylinder"? Have you checked compression in all 4 cylinders?
Old Nov 8, 2011 | 04:01 AM
grumblemarc's Avatar
The Grumpiest
Compression and leakdown test.
Old Nov 10, 2011 | 01:16 AM
Technical Hero
Also did you put the spark plug wires back in the proper order?
slowwcivic
May 25, 2011 06:18 AM
justinCO
Jun 5, 2008 08:19 PM
seriot
Apr 2, 2008 11:46 AM
5lugSlug
Jul 19, 2004 07:34 PM
