94 accord rear disc brake pads won't fit
Hi guys,
I need your help. I have been struggling with my rear disc brakes for a while now. Every time i need a new set, and im ready to install they won't fit. once i slide the caliper back on they lock and disc will not turn. i have gone to the auto part store many times to make sure i got the right ones, and everything is good.
What is the problem? why do they feel lock when i put the caliper back on??
Thanks!!
Thanks!!
Check that the piston is turned backed and properly aligned with the brake pad tab, the piston should be turned so that it looks like a " + " around the center points of the caliper, which should then align with the tab near the center top of the brake pad.
Then after that sometimes you have to slightly push the slide pin in a little so the caliper can slide on.
slave2waf
47
Feb 23, 2024 04:06 PM
Kevin Nealis
Apr 19, 2015 07:53 PM
