ok, is a inline fuel pump necessary for my set-up? (look inside)
first off,
DID the search! sooooo, this is what I'm gathering from my research
I'm running the a greddy kit at 7-8 psi, blue box isn't working for me
I have Greddy 310 injectors (not RC)
I currently have a vortech 12:1 fmu
Soo my questions are, Is an inline fuel pump necessary for this amount of boost?
and
8:1 seems to be the preferred disks while others argue that 10:1 and 6:1 are better for (insert reasoning) can anybody enlighten me on this?
like always, TIA
BTW, I will be posting a pic of my pump, I have no damn clue what goes where, if you guys could let me know that would be cool also
Mick
and
like always, TIA
Mick
yea go with 8:1 because 12:1 fmu disk is too high. Im running 8:1 with intank fuel pump and vafc. If you go 12:1 use an inline pump, otherwise if you go 8:1 its ok to use an intank cause fuel pressure will not be as high
[Modified by NHB Fighter, 7:09 PM 10/6/2002]
first off,
and
like always, TIA
Mick
and
like always, TIA
Mick
No, I'm sorry,
I meant to say, I use to run the blue box but I took it out for the FMU,
so it's ok to use an INTANK fuel pump with 310's and 8:1???
NO! you need an inline fuel pump to be able to feed the FMU the pressure it needs to properly function.
INLINE WITH AN FMU
Rob
[Modified by rjardy, 12:44 PM 10/7/2002]
INLINE WITH AN FMU
Rob
am using a 255 intank!
280 prelude injectors
12:1 vortec FMU
no problems whatsoever...
did i mention 9-10 psi on a stock LS!!!
Tyler
12:1 vortec FMU
Tyler
12:1 vortec FMU
Tyler
12:1 vortec FMU
Tyler
How do you know that you are not detonating? Had your a/f ratio measured with a bideband o2 sensor NO! I promise you that if you get it measured you will be lean. YOU NEED high pressure to operate the FMU corectly. end of story. A intank 255 lph pump is not enough.
Rob
[Modified by rjardy, 1:34 PM 10/7/2002]
Ok Ok OK,
Think i'm going to run the bosch inline
Anybody want to let me know about this pump, it's minehttp://hometown.aol.com/pir8168/mickpic.JPG
what's inlet, what's outlet?
I need a relay huh?
Where am I suppose to find the fuel pump wire? the green and yellow one
I need a relay huh?
12:1 vortec FMU
Tyler
12:1 vortec FMU
Tyler
art
Running Greddy Kit (no blue box) with Vortech FMU and Bosch inline pump on a B16a1. 6 psi for now..........
[Modified by ee8T, 11:00 PM 10/7/2002]
