turbo lsvtec oringed blowning headgaskets
This is the second time it doesn't blow bad just enough to.notice my coolant level dropping and white smoke randomly its 84 mm lsvtec cometic gasket and o ringed I fresh decked head and all it was fine for 1k miles untill I went to the track it got alittle warm when I put it into fourth gear. It a 6262 setup on pump gas making 538 whp. Anyone have issues with the o rings I was woundering if I can put a new gasket.on it without orings but I don't think it will seal right.
Your problem is more likely with the cometic gasket and not the o-rings. You said warm how hot is warm. And to answer you question I wouldent unlees you want this to happen again. I would take it off send it to a machine shop make sure everything looks ok and buy an OEM head gasket
Temp gauge went up slightly not much I hit the heat and it went right back to normal but it wasn't low on coolant then I havnt been able to get it hot again but its been useing alittle coolant I put a pressure gauge on it when It was cold and it climbed to 24 slowly then I kept the pressure on it for a bit went to start it again and it misfired at first
I'll never ever run a cometic gasket there junk the first one I had the car never made it off the dyno golden eagle all day never had a problem with them
I love the automatic blame on the Cometic head gasket when an Oring'd block creates much more room for error. I run a .051" Cometic gasket 84mm, 29psi, 500hp, zero problems. Personally I dont think you need to consider Oring until your bore is above 84.5mm on a B series.
The second gasket u bought was a cometic (now it blew)
Are you really going to consider putting on another Cometic gasket seriously? My opinion is to go with an OEM gasket im getting ready to do a b16a GE sleeved & maybe bore to 84mm & thats what im running or GE...OEM is the only one that ive never heard give problems for the ratio of cars that run them..
I think you may have another reason here why u keep blowing them though.. was it machined after the 1st one blew or just replaced & slapped back on? take it back to the shop bc it might be slightly warped now since this is the 2nd time & get a GE or OEM gasket...
What did I use?
Toyota Genuine Factory Silicone Gasket Sealant - NO COPPER SPRAY on Cometic Headgaskets. Use a very thin layer with your fingers to cover both sides of the gasket prior to installtion.
Used it on my Cometic Gasket on my wife's 81.5mm TODA CIVIC. That was 2 years ago, and haven't had a problem since.
But if you can get OEM, get OEM.. if Not, please try my solution.. it works quite well if using a COMETIC headgasket.
As far as the shop I was dealing with I left them because of all the problems.I've had on this rebuild I have 2 other options of what happened this block when.the first gasket went also had a sleeve leak and had to be resleeved they fixed that and gave me a longblock back so I figured it was partially from that on the first gasket I also no they had to remove the head and tourqe it atleast 6 times to get everything right note they didn't change the headstuds I questioned them on this they bullshitted.me on it. The only other thing was.I messed with anti lag at the track maybe I got it alittle lean but I would of though it woulda blew bad on the line of I did that
I had solved the "COMETIC HEADGASKET PROBLEM" years ago. Its the preparation of the gasket based on the MLS construction, not the "quality" of the gasket itself.
What did I use?
What did I use?
Should start a thread called "Cometic Gasket problem FIXED" and see the replies lol...
As I said in my last post, we covered the entire gasket with a very thin layer of this stuff. And I mean VERY THIN
We used the DEALER ISSUED STUFF.. just like you would if you bought Hondabond.
After working with Yoshio Kinoshita at Japanese Automotive, he and I came up with the idea, after a friend of mine was going through the same ordeal in 2006 on his 250whp Civic used in H1 class.. I guess Different compound of chemicals than Hondabond (Kinda what makes Hondabond Hondabond ya know?). After we tried it on a couple of cars and got feedback 2-3 years later, they had no sealing issues whatsoever.. so, we stuck with it.
Used the Ls/Vtec cometic gasket .030" on my o-ringed block... less than 100 miles later headgasket issues... Switched to OEM LS headgasket and never had a issue since.
yO Mac, your living in the 80's maaaaaaaan..... (j/k) Have you tried this shiz http://www.buyracingparts.com/hyloma...sol-spray.html Its the real deal maaaaaan... Propa racing stuff.
I see... i have some here which i may try out on my build. I was only messing about the 80's part, i don't think that at all
. (These damn American's not understanding us Brit's hey ???
