b16 timing
so i bought a new distributor today. and before i bolted it on, i wanted to make sure that everything was still in time.
well everything wasnt. it looked to be a tooth off, and i think that would explain my low idle and stumble the other day.
anyways i timed the bottom end, and i timed the top end, but whenever i go to tension the belt, nothing happens.
the last time i put everything on, which was 15 mins ago, i got both sides of the timing belt tightened, but the top was loose and i didnt want to just leave it at that.
anything for a quick fix to at least get the car running?
Ok, so you lined everything up at TDC (both crank at white line and cams), you have the belt on. Before you go to tighten up the tensioner did you rotate the crank (counterclockwise) 3 teeth to put the proper tension on the belt? Sounds like you just tightened it without tensioning it therefore making it so its too loose like its not even tensioned.
thats my problem
Sounds like either you have the wrong belt or your tensioner isn't moving to pull out the slack. Is the tensioner pulley bolt loose and can you move the tensioner back and forth with your hands?
i think what i might do, is actually ziptie the belt onto the cam gears that way i can focus more on the sides
just attempted to do the timing once more.
i used a zip tie on the cam gears to keep em from rotating, but its SUPER hard to keep the crank pulley from spinning while tryin to force on the belt
Most definately lol. Now from where I have read the two inner lines need to be completly straight and the "up" arrows of course pointing up. Sometimes I can get everything sooo close and it is like half a tooth from the belt sliding and and fitting right. But tomorrow I am going to use the same method I ddid before and have someone hole the crank still lol
i think its shot, but if i can get if pushed up somehow i can get everything working and at least get the car running and driveable
Instead of zipties on my DOHC zc I took off my valve cover and inserted to drill bits into the top of each cam cover (with cams at TDC) to keep both cams at TDC. Works better than zipties to keep them there.
anywho i got the timing correct. buddy of mine helped me out. and the tensioner is actually good.
Regardless, I do mine by myself with no "silly" methods or "tricks". You guys need to learn how to clock things... and get some "man hands". Also, OP - I hope you understand that the engine rotates Counter Clockwise...
Dude you miss understood me. I use drill bits to put in the cam cap (which already has a hole that lines up perfectly with the hole in your cam at TDC), I'm not using the drill bits to drill into my cam cap or my cam. lol so yea when im done I take out the drill bits.
timing is definatly better. my tensioner was good, and i took the hatch for its first test drive in over a year!!
Mishako129
Sep 4, 2012 10:14 PM
Ag3nt_Orang3
Jan 28, 2006 11:36 AM
