stolen recovery help
Old Nov 6, 2011 | 08:45 AM
TruVa's Avatar
Default stolen recovery help
recently recovered my stolen 95 Teg. the steering wheel was broken so i had to replace the whole steering column. idk what else was done to the car but for some reason the fuel pump wont come on. all they stole was the rims and system. i checked the fuses and the ign fuse was burnt so i replaced it but it still wont cut on. any idea of what could of happen ? if the ignition is tempered with could the car go on theft mode? it doesnt have a alarm system.
your help would be greatly appreciated thanks
Old Nov 6, 2011 | 09:22 AM
vinem1's Avatar
Default Re: stolen recovery help
Did you try to replace your ignition switch ? also did you check all your fuses?
Old Nov 6, 2011 | 10:23 AM
DeeC2's Avatar
10 Year Member
there is no theft mode on the 95
Old Nov 6, 2011 | 05:00 PM
TruVa's Avatar
yes checked everything and replaced the ignition switch also checked the relay. i am thinking its the fuel pump.....will check it tomorrow, thanks for your input though
Old Nov 8, 2011 | 05:15 PM
TruVa's Avatar
replaced the fuel pump checked fuses and relay everything good but the fuel pump is not coming on, any idea on how to check if the pump is getting power?
Old Nov 8, 2011 | 05:32 PM
fcm's Avatar
fcm
Old Fart
Drop the PGM-FI Main Relay and test the yellow/green lead as you turn on the ign. 94
NovaRex
Jan 27, 2016 06:59 AM
jtheshowstopppe
Jan 2, 2016 08:28 PM
kevodean
May 17, 2011 12:47 PM
jianwa
Jul 31, 2010 02:03 PM
GSR_hatch936
Feb 25, 2010 04:07 AM
