Looking for 96-98 door wiring plug pinout
Old Nov 6, 2011 | 07:02 AM
dwillms's Avatar
Default Looking for 96-98 door wiring plug pinout
Common problem on my EK:
I figured out how to depin the plug to fix it correctly, but I can't find a pinout for the wiring diagram anywhere. 96 EX coupe.
Couldn't find anything on a search or in the shop manual.
Any help? Thanks!
Old Nov 6, 2011 | 11:33 AM
Former User's Avatar
Default Re: Looking for 96-98 door wiring plug pinout
Old Nov 6, 2011 | 02:35 PM
dwillms's Avatar
Thank you x 1 million.
What page is that in the Helms?
Old Nov 6, 2011 | 03:27 PM
202-21
Old Oct 30, 2013 | 07:49 AM
ekhaze's Avatar
I know this thread is old, but the pinout diagram still makes it very useful (to me and likely others sooner or later).
Any chance anyone knows what style of replacement pins one would need to repin this plug with new connections? I have to go back into my door connector to repair again (used a pigtail from a salage yard civic years ago) after body shop messed up my previous work apparently and i might want or need to use some new pins..
ive repinned other connectors in my civic but its been a minute...
Ballenger Motorsports might have these but which ones?
http://www.bmotorsports.com/shop/
Old Nov 1, 2013 | 08:27 AM
k_than's Avatar
how did you depin the plug?i had the same issue and could not figure out how to depin it.thanks
Old May 4, 2015 | 12:54 PM
mgreene's Avatar
Originally Posted by RonJ@HT
RON J, Iknow this was an older post but do you have a similar diagram for a 96 civic lx. I tried this diagram but the wire color doesn't seem to match up with whats there. Also any info on removing the old pins from the connecter would be very helpful. Thanks
Old May 4, 2015 | 03:27 PM
The diagram should be a perfect fit for the 96 LX. Point out discrepancies.
Old May 6, 2015 | 06:59 PM
mgreene's Avatar
RonJ, someone had to have removed, replaced some of these in the wrong spots. My body harness was tampered with but after removing the inner door plug as well as the passenger side door, I found wires that matched the info posted. Thank you very much
Old Aug 5, 2019 | 08:41 AM
kevin Mckoy's Avatar
Default Re: Looking for 1990 civic 4dr driver door wiring plug pinout
I got all my windows stuck up now and need to fix can some send me the layout of the door plug diagram I would greatly appreciate it
Thanks
Old Aug 7, 2019 | 04:44 AM
muellersfan's Avatar
Thanks
Post your question in the CRX/EF forum.
bfischer
Honda CR-V & Element
10
Jun 29, 2022 12:47 PM
Jonnywalker335
May 26, 2014 11:26 AM
nisdat720
Apr 2, 2010 11:18 AM
