92 Civic hatch - How install Gauges?
Anyone have any idea on how to install an oil pressure gauge, volt gauge, and fuel pressure gauge? Im looking into buying all three for my 92 eg hatch but wanna make sure i can install them before i buy em. They would all run into a triple gauge pod.
Any walkthroughs or anything would be awesome. Any help is better than none
It's got to be about the easiest thing you can do. Power, ground and whatever runs to signal the gauges. Since you failed to mention what type of gauge, mechanical or electrical, that part is also not too difficult to figure out. Fuel pressure installs on your rail or on teh fuel filter. Plenty of walk-throughs on the internet to be found.
ill look into autometer, but what do you guys think about these?
http://www.glowshiftdirect.com/
they make some 3 pod combos for around $200
if i were you tho, i would run an oil pressure gauge, oil temperature gauge, and a vacuum gauge. a "vacuum gauge" is a very good friend to have when diagnosing engine problems.
Another WOW factor thread.
Heaven forbid we save someone hundreds or thousands of dollars.
Looks like a cam, Hondata and some bolt-ons. That's why I say "slightly".
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/mods-tune-2980118/
Google works too...most times a honda-tech thread will show up in the results. Then after that you may have questions....IJS.
i just searched on google and these were in the top 3 results each time:
http://www.grandamgt.com/voltage.html
http://www.grandprix.net/upgrades/oilgauge.html
http://bernardembden.com/xjs/fpgauge/index.htm
Search next time.
/thread
Search next time.
/thread
Honestly I use vdo gauges in both my civic's and they have worked well for me, I run voltmeter and oil pressure. I have the cockpit series in one and the other car I got the vision series.
