Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Honda Civic 07 COUPE replace wiper blades
Old Nov 5, 2011 | 08:03 AM
hyu968's Avatar
Default Honda Civic 07 COUPE replace wiper blades
I am trying to replace wiper blades on my Honda Civic 07 COUPE. The wiper blades are almost 4 years old :) I bought a pair of new Rain-X latitude which are supposed to fit my COUPE. The problem is I cannot remove the original blades from the car. All instructions I have seen have a different mechanism. Do you guys have any idea how to replace them on 07 coupe? Any advice would highly appreciated. Thanks!
Old Nov 5, 2011 | 12:46 PM
07SIcpe's Avatar
Default Re: Honda Civic 07 COUPE replace wiper blades
take those back they dont work on our cars..I know, I tried..get wiper blade inserts from honda..the end of the wiper blade has a little piece that you slide off and pull the wiper blade out, then slide the new one in..very simple actually takes a few minutes..and MUCH cheaper...
Old Nov 6, 2011 | 06:55 AM
bee guz's Avatar
Advance auto has blades that fit those cars, I had a problem finding blades to fit my 06, I can't remember the name of the blade, but they were way cheaper than buying them from the stealer.
Go to advance and they will put them on for you free, if you have problems doing it yourself.
Old Nov 6, 2011 | 08:17 AM
07SIcpe's Avatar
I payed $6 for both wiper blade inserts from the dealership..pretty good price I'd say...
Old Nov 7, 2011 | 07:29 AM
bee guz's Avatar
6 bucks at the dealer? You must have caught them in a good mood...LOL
Old Nov 7, 2011 | 02:50 PM
07SIcpe's Avatar
lol no it may be because I worked at a body shop and had them call and order them so I got them for cost..
Old Jan 1, 2012 | 01:00 AM
jpweigand's Avatar
$6something here in tulsa for just the rubber insert. jpw
Old Jan 28, 2012 | 02:00 AM
theaxman's Avatar
Actually, the RAIN-X Latitude wipers do fit and work fine. It takes a 28" and a 24" wiper. I installed them on my 07 Civic Coupe after initially having trouble following the directions included with the wiper blades, but then finding this video on YouTube:
http://www.youtube.com/watch?v=nJ21dZirBWY
Good luck!
Old Jan 28, 2012 | 01:32 PM
DaveSi677's Avatar
Good find!
Old Jan 29, 2012 | 10:08 AM
Blk06Si's Avatar
Stick with the OEM blades then you can just replace the rubber inserts instead of replacing blades everytime.
Old Jan 29, 2013 | 04:44 PM
ssgohan77788's Avatar
but it is good to replace the blades some times because over time the old blade will stretch out and not hug the window as tight
Old Jan 29, 2013 | 09:08 PM
av911's Avatar
I have replaced my blades only ONCE in my 7 years of ownership of this car. Still works great. But I'm using Rain-x windshield washer, so, that does most of the job.
Old Jan 30, 2013 | 01:56 PM
97emsedan's Avatar
The OE blades are easier to install and cheaper than buying entire blade assemblies... the RainX blades might fit, but they are a lot more expensive... keep the OE blades and use the RainX fluid... same thing isn't it?!!
Old Feb 4, 2013 | 02:56 AM
frydrce's Avatar
The oe inserts are way cheaper than the rain x or bosch icons. way easier to install as well. I also figured I got about 4 years out of them.
Old Feb 11, 2025 | 10:31 PM
lilxkard's Avatar
hello question I have the Bosch icon and for 3 weeks cannot figure out what adapter I need and was hoping you knew which one you used for ur coupe
accordmurdera
Aug 8, 2012 06:08 AM
spoon.ek
Honda Civic (2001 - 2005)
Jun 11, 2009 04:36 AM
DC_Civic08
Mar 26, 2008 10:00 AM
stinkypinky1011
Jul 30, 2007 06:06 PM
