dpfi to mpfi code 10 wont crank
hey guys please help.ive done my second dpfi to mpfi swap this time using z6 intake and the only code im throwing is code 10 but it wont even crank it tries to turn over then it just cycles and randomly backfires out the exhaust.i know i have fuel and spark and yet it wont even crank through limp mode.wtf please help
change the iat plug on the manifold or make sure you plugged the correct plug to the sensor.
i always got the iat and the iavc plugs mixed (idk why) and my z6 manifold i bought had the sensor all chewed up for some reason. but..that shouldnt stop the car from starting though.
care to explain the steps YOU did according to what ever write up you used?
make sure you tapped into the correct wire on the dizzy
also check for map and tps connectors being in there right order, im betting on this forsure. motor still might start but wont hold idle. flip the tps with map connectors and see what the outcome.
good luck.
good luck.
if i remember correctly code 10 is Intake air temp that would not affect your car from running.
you know what and you say you have spark and fuel. so its not the dizzy wiring,
Im all in on the throttlle postion sensor and manifold app pressure connectors are backwards.
okay so that fixed the cel problem even though the tps now is too short and wont plug up.im gonna extend that today but when i tried it yesterday it still wouldnt crank,ill guess ill throw some ground on the underside of the block and hope for the best.
just for referance i did a full wire tuck while doin the mpfi swap on it thats why im soo sure my problem is definatly in wiring but i also used as litle number off grounds on the motor as possible.could this have something to do with the battery being relocated to hte hatch at the same time?
yeah, check all your grounds especially the negative terminal, make sure its in a good place in the trunk. add a ground from the trans to the chassis and see if it'll start up.
This was his first post...... so obviously it turns over.
yes it turns over theirfore the crank rotates butit doesnt crank still.i double checked the firing order and its correct i know im getting fuel and lots of it.mabey the injector order is wrong or something.it backfired out the intake a few nights ago which is usually due to timing being waaaayyy off but its tdc on the dizzy and i even put th engine on tdc cylinder one and oulled the cao iff and the rotor was in the right spot.is anyone in the 843 florence area that could give me a hand?you know its bad when i ask for personal help. and 10psilsef2 your a ****in G!!!!
no it sounds just like it should but it just turns and turns and turns but wont run on its on.just keeps trying to turn over but as soon as you let off the key its back to nuthing.and heres a random thing is it shows rpm when the ignition is switched on
i got it to crank and its throwing code 7 and the teg ls/se ecu make it idle high as ****.thank you guys for all of your help.the wiring was completley correct the dissy was ****ed up on the inside after a frankeinstein rebuild it purs like a kitten with royal purple for blood
scoobyghost
Jun 19, 2004 12:21 PM
