ob2a harness/obd1 Ecu/96 civic -- i need some serious harness and wiring help.
Old Nov 4, 2011 | 12:35 PM
boostedhearts's Avatar
Default ob2a harness/obd1 Ecu/96 civic -- i need some serious harness and wiring help.
OK.. so I have a ob2a harness and obd1 Ecu and a 96 civic with a built b16. I did some harness work to touch up some stuff and do a rerout but I think I screwed up. So I have 4 questions.
Are both pins on the injector plugs supposed to have power?
The ckfm m side pin c31 is that to be hooked up still even with a obd1 ecu?
Does the air intake temp sensor have a ground or power constant?
What are the three wires on the vss?
And my final is I can only find one coolant temp sensor. I have the guage single wire one what are the wire colors for the other two and are they powered or grounded? Anyone who really knows harnesses and has a few mins please text me 406 478 1784
Thanks a bunch!
Old Nov 4, 2011 | 02:23 PM
Default Re: ob2a harness/obd1 Ecu/96 civic -- i need some serious harness and wiring help.
Also is logic ground just a regular ground?
Matt91
May 1, 2010 02:48 PM
jdmdikk
Apr 15, 2009 07:55 AM
perseverance
Mar 29, 2008 12:16 PM
Slava.
Mar 23, 2006 03:07 PM
turbo sol
Dec 9, 2004 04:19 PM
