Custom intake,How can i adapt an IAC valve
Old Nov 3, 2011 | 09:29 PM
rfelix89's Avatar
Default Custom intake,How can i adapt an IAC valve
soo i have a custom intake manifold. its looks kinda like the round venom manifolds.
so heres my issue. my rpms surge from 1200 to 1700 rpm when i have my foot lightly on the pedal, i was told it was cuz i dont have an IAC hooked up. but my intake manifold doesnt have a location for it. is there anyway i could adapt one?
thanks for all your input guys.
Old Nov 3, 2011 | 09:37 PM
rfelix89's Avatar
Default Re: Custom intake,How can i adapt an IAC valve
[/IMG]
this is a picture of my setup
Old Nov 4, 2011 | 04:19 AM
MR.johnson's Avatar
The easiest way wound be to disable iacv in the ecu without doing modifications to the manifold. I ran a mustang tb with no iacv.
Old Nov 4, 2011 | 05:54 AM
kbouchard1092's Avatar
That would be the easiest way...
I had this happen on my SOHC manifold a long time ago....we got a block of aluminum curved it to match IM then tig welded it to it....then drilled one hole straight thru to manifold ( cant do this on the car needs to be taken off) and the other we made exit out the side of the block and ran a hose pre TB. YOu have to thread two holes so you can bolt IACV it to the adapter.
Its a PIA best bet might be just get a new manifold.
Old Nov 4, 2011 | 06:07 AM
sdubfid's Avatar
What about a remote iacv? t1 makes a plate i think.
Old Nov 4, 2011 | 06:19 AM
Yea that would be much easier if they sell some type of adapter where you can mount it on firewall and just run hoses...i had the manifold off at the time and we decided to make a block adapter....If T1 sells a adapter that would be youre best bet
Old Nov 4, 2011 | 07:07 AM
ashb82's Avatar
sounds like something else, i dont run a iacv either my car idles steady and never has unstable rpm issues. i do have it disabled in ectune
Old Nov 4, 2011 | 07:16 AM
bgdriver's Avatar
I have a custom im and 70mm with out IACV on a stock p28 with no problems
Old Nov 4, 2011 | 09:30 AM
rfelix89's Avatar
thank you guys for the input. im gonna have my car tuned on s300 soo ill wait till then to see how it acts with the IAC disabled
Old Nov 4, 2011 | 10:32 AM
Yea sounds like you will be fine without it...i had a stock ecu when i had made the adapter...i run the S300 now but i still have the IACV.
Old Nov 4, 2011 | 12:44 PM
SpeedwayCoating's Avatar
I have a remote IACV adaptor that I mounted to the firewall under my intake, then welded a -8 bung to both the charge pipe in front of the tb and one to the intake manifold and connected it. Worked really well. I had the adapter cut out on a water-jet.
Old Nov 4, 2011 | 05:26 PM
rfelix89's Avatar
would you mind posting a picture?
Old Nov 4, 2011 | 08:12 PM
b18cya94's Avatar
www.bmcrace.com makes a remote one.. thats what im running.. heres a pic of it just lying on top of the manifold..
sflemon
Aug 19, 2010 06:15 PM
.RTErnie
Welding / Fabrication
21
Sep 17, 2007 07:07 AM
IT'S ME DAVID
Jan 15, 2007 11:55 PM
mr. carpenter
Apr 17, 2005 07:13 PM
comptechgsr2000
May 13, 2002 09:15 PM
