Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Drivers side water leak
Old Nov 3, 2011 | 03:37 PM
Xplod590's Avatar
Default Drivers side water leak
I am new and wanted to see if anyone has had this problem. When it rains my drivers side floor (front & back) is getting soaked. I have looked and looked for a leak and cant find nothing, not no water trails on any of my panels or seat. I have had someone inside the car while i spray it with a water hose and cant find anything. Other than my door gets full real quick so the water comes in from the seal that presses against the window but my passenser side does the same thing. I have already got to replace my carpet because of this problem so if anyone can help or give me suggestions please let me know. Thanks
Old Nov 3, 2011 | 03:47 PM
Xplod590's Avatar
Default Re: Drivers side water leak
Sorry I have a 04 Civic Ex 2door. I do have a sunroof. The honda place told me that would probably be my problem but wanted $135 to check it.
Old Nov 3, 2011 | 04:35 PM
lazlong's Avatar
Probably the sunroof drain hose has become detached. Put your head near the pedals and look at the sidewall of the car (left side). You should see the drain hose. If it's still attached and not plugged up then find where it comes out the bottom of the car and see if it's plugged. You have 4- 1 down each A pillar and 2 down each C pillar.
Here a pic of what I'm talking about:
Old Nov 3, 2011 | 04:52 PM
Xplod590's Avatar
I check that and I put silicone around the hose just to make sure that was not my problem. i will check this again just to be on the safe side. Any more suggestions? I am wanting to try to find this before winter sits in.
Old Nov 3, 2011 | 05:31 PM
lazlong's Avatar
Next time it gets wet pull all the covers on the pillars to check for water. Also, check and replace any worn gaskets (doors, windows, trunk, sunroof, etc.) or grommets (in the firwall).
Old Nov 24, 2011 | 09:39 AM
Xplod590's Avatar
i checked it when it rained hard again but i seen nothing. i poured water into my moonroof tubes and they came out fine onto the ground so i dont think that its my moonroof tubes. i still have not seen anything on my panels after it rains but my "pool" of water seems like it is getting worse. i also have been told to check the plugs underneith the car and they are fine. anyone got any help for me???
Old Nov 24, 2011 | 03:18 PM
lazlong's Avatar
Maybe firewall grommet(s) or a leak in or around the cowl (piece between the hood and windshield).
Old Nov 27, 2011 | 11:03 AM
It Wasn't Me's Avatar
Any water in the trunk?
91EFCIVICII
Feb 28, 2011 11:56 AM
acura4me
Acura TL, RL & ZDX
Jun 16, 2009 09:08 AM
Armorzaku
Feb 21, 2009 12:27 AM
awdgsx96
Oct 30, 2007 02:39 AM
