front end noise
Old Nov 3, 2011 | 03:33 PM
Dakine69302's Avatar
Default front end noise
I started noticing a noise from the front end of my car, the only thing i can relate it to is it sounds kind of like a helicopter, and it goes faster as i go faster, and i know it's nothing with the engine because if i push the clutch in and let the car idle while i'm on the highway it still does it.
Old Nov 3, 2011 | 06:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: front end noise
"whoomp whoomp whoomp whoomp" Is that the sound? Possibly a wheel bearing. Jack up the front and check for excessive play by pulling on the wheels at 3 and 9 O'clock, and again at 12 and 6 O'clock. If one side seems sloppier than the other, then you may have found your issue.
Old Nov 4, 2011 | 12:44 PM
yes it is a "whoomp whoomp" noise, and i tried checkin for excessive play but couldn't really feel any. How much of a pain in the *** is it to get to the wheel bearings on this car, sorry i just bought this car and i'm very unfamiliar with them.
Old Nov 7, 2011 | 03:30 AM
steelhitman1245's Avatar
yeah i agree, sounds like a wheel bearing. if you're not familiar with your car, go out to your auto parts store and pick up the Haynes repair manual for it. It'll be the best $25 you could spend.
Old Nov 8, 2011 | 07:52 AM
thought it might be a wheel bearing, thanks for your help.
Old Nov 8, 2011 | 12:52 PM
StreetsideStig's Avatar
You can also check wheel and tire balance.
asianman139608
Jul 2, 2010 06:41 PM
tunes12
12
Aug 28, 2007 04:54 PM
tunes12
Apr 20, 2007 07:08 AM
Josh.
14
May 30, 2005 09:47 PM
