Complicated A/c heater lights flicker problem please help
Old Nov 3, 2011 | 12:05 PM
accord99power's Avatar
Default Complicated A/c heater lights flicker problem please help
On my 99 honda accord ex 4cyl, i am having an issue with the cold/hot air selection lights flickering. (I.e. defroster, leg air , leg and head air lights, inside air, a/c lights) The function is working for the most part ex: i can turn the air on and off, etc.
*Almost seems like it is extremely low on power and will barely read what your pressing.
Its really not constant with anything unfortunetly.
*when the car is turned off but in accessories position(fans blow) the lights dont come on at all.
*when the car is started the lights flicker, if i unplug the plug from the back of the controls then plug it back in the light will stay solid for a few minutes but once i press another selection(ex:inside air) lights flicker again
Tested and cleaned the battery terminals, checked grounds, wiggled wires around.
when car on is reading 14.2 volts.
What else can i test here??
Old Nov 4, 2011 | 04:47 PM
Default Re: Complicated A/c heater lights flicker problem please help
bump
Old Nov 4, 2011 | 04:54 PM
exb18c1's Avatar
Originally Posted by accord99power
bump
Looks like the re is a power side bad contact somewhere.First,is the control is automatic or manual?I'm assuming is automatic.I would check the power supply soldering points in the back of it.Make sure there are no cracks on the board.
Old Jul 31, 2012 | 05:32 PM
DabbiFresh's Avatar
accord99power did you figure out what it was? mine started doing this the other day and through searching came across this.
andre3wap
Jan 27, 2014 09:08 AM
JDMkid98ls
Dec 2, 2008 04:47 PM
CHONCH
Nov 17, 2004 05:02 PM
EJ8 GSR-T
Aug 27, 2004 08:08 PM
Blockhead G
Jun 28, 2002 11:44 AM
