Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
How to tell which bank has a blown HG on a TL
Old Nov 3, 2011 | 10:26 AM
Blaze45's Avatar
Brrraaaap!
Default How to tell which bank has a blown HG on a TL
I am looking into buying a 1998 TL that may have a blown headgasket. Is there any way to tell which bank NEEDS to be replaced? I know, the proper way is to replace both of them and I may end up doing that. I was just curious if there was a sure fire way to know if one bank is toast? Also, has anyone herd any issues with these HGs going bad or any block/headbolt issues sealing? The engine has 211k so.... I know these tranny's had issues. It was replaced by the dealership @ 118k or so...
Thanks for your input!
Blaze
Old Nov 3, 2011 | 08:53 PM
lazlong's Avatar
Default Re: How to tell which bank has a blown HG on a TL
You do a compression test then you do a leak-down test if your losing any compression.
Great video of a compression test:
http://www.youtube.com/watch?v=X_tbksFYhl4
Same guy, leak-down test:
http://www.youtube.com/watch?v=WgrfT0LFMhc
Old Nov 4, 2011 | 02:34 PM
civichxtreme2's Avatar
Ive seen instancs where neither of these showed negligable differences, If I were you I would just replace them both, if ones gone then the other may not be too far away.
Old Nov 11, 2011 | 01:43 PM
tlarimer's Avatar
BHG are a very common problem in the C32/C35 engines. Check out acuralegend.org and in the FAQ there are a few test's to verify which bank and cylinder or cylinders are leaking.
If it were me, I would do both, since you're going in that far anyways, it's only a handful more bolts to replace the other HG at the same time. I would do the Timing belt and Water pump too at that time.
If I was a little closer, I could lend a hand.
humboldt_skim
May 31, 2008 08:18 AM
vteg98
Oct 15, 2006 06:07 PM
b18c1acura
Jun 22, 2005 04:40 PM
Propulsion
Jun 5, 2002 11:48 PM
Jordan_4WS
Apr 23, 2002 02:58 PM
