2003 EP3 wheelspin knock
You'll get some better help if you post in the appropriate forum.
https://honda-tech.com/forums/forumdisplay.php?f=32
i would want to figure out why it's loosing traction before i figure what's making that noise... but yea, speedoo is right. post in the correct forum and you'll get some better help.
Welcome to Honda-tech, look like they moved your thread to the EP3 forum.
Check your motor mounts and make sure they aren't torn. Also check your tire pressure, make sure its 32-35psi on all 4 wheels (depending on your wheel/tire setup).
How many miles are on your car?
Also - if you start to have wheel spin, try to modulate the throttle so you aren't wheel-hopping all over the place. It's bad for the transmission and a slew of other parts that like to break. If you're getting wheel spin from a dig then learn to launch better.
Thanks for the feedback, should have worded my thread better,makes me sound like boy racer!.Had my car 6 yrs mint condition,only just got 50k on clock.Only spinning when pulling out quick!
It's probably a combination of wheel hop and bad mounts. The wheel hop makes mounts go bad, bad mounts makes the wheel hop worse, then you get the banging noise...
CoupeKidz13
Sep 2, 2011 11:20 PM
Clay@tirerack
Nov 15, 2005 08:53 PM
