Trunk leaks!!!!!!!!
Old Nov 3, 2011 | 12:06 AM
ghettoda9's Avatar
Icon3 Trunk leaks!!!!!!!!
Hey I just got a 93 civic ex coupe and I saw water start to build up in my trunk. My da9 had the same and I unclogged some drain holes under the car by the tow hook. Are civic coupes the same way? And if not where can I troubleshoot the leak? Any help would be appreciated thanks.
Old Nov 3, 2011 | 12:14 AM
rickyracer's Avatar
Default Re: Trunk leaks!!!!!!!!
the rubber that seals the trunk, or even the taillight gasket might be bad....
Old Nov 3, 2011 | 06:18 AM
D Griff's Avatar
Get some silicone clear caulk stuff and spread it around the rim of the trunk, under the the edges of the lid if that makes sense. There is a seam there that usually seperates. This is probably your problem. To find the leak, get in the car and have a friend spray it with the hose, then you can see where the water is entering.
Old Nov 3, 2011 | 07:18 AM
Wrona's Avatar
what i would do is take a hose narrow it down from where its leaking from by pouring water onto the trunk and replacing that gasket silicone is only a temporary fix... its probably your tail light gaskets they go bad after all these years
Old Nov 3, 2011 | 07:21 AM
D Griff's Avatar
I siliconed it when I bought my Civic in 2006 and it's still dry, if that's what you call temporary. We may be talking about something different, but it worked great for me (I have a 96-00).
Old Nov 3, 2011 | 07:27 AM
Wrona's Avatar
well thats good everytime ive seen someone use silicone it didnt work out for a long period of time but maybe they didnt get the good stuff who knows but if it would be the tail light gasket those are not that expensive
Old Nov 3, 2011 | 03:44 PM
chasingadrenali's Avatar
lay in the trunk with a flashlight, have someone take a water hose and spray the seams of the trunk and see if water is coming through anywhere, if not, there is likely to be a hole in the bottom of your trunk.
Old Nov 3, 2011 | 09:53 PM
j.dmcar's Avatar
i guess you gotta use silicone .. some water proof ones.. try and locate all the leaks though.
tstein23
Honda Civic (2001 - 2005)
May 17, 2014 04:12 AM
squeaks
14
Mar 9, 2011 11:53 AM
foomashoo
Dec 12, 2004 03:48 PM
cdntegintx
Jun 24, 2004 07:45 PM
.ShawnD.
Apr 26, 2004 10:33 AM
