recommended tire psi??
Old Nov 2, 2011 | 07:38 PM
pliskin8's Avatar
Icon2 recommended tire psi??
i've been searching around but havent found an answer, i just want to know whats the best tire preasure to run for a 195 50 15 tire(currently running 35psi)
Old Nov 2, 2011 | 07:51 PM
grumblemarc's Avatar
The Grumpiest
Default Re: recommended tire psi??
Whatever's in the manual. I think what you have is fine.
Old Nov 2, 2011 | 07:55 PM
pliskin8's Avatar
well it's an aftermarket wheel setup that's why i was double checking, thanx
Old Nov 2, 2011 | 07:56 PM
Kohen's Avatar
for your tires 32psi is recommended. 3psi is no big deal though.
Old Nov 2, 2011 | 07:57 PM
RamosKiiD's Avatar
Yuhp your good man
Old Nov 2, 2011 | 08:03 PM
egsleepercivic's Avatar
what brand of tire, I noticed on falken zeix 512s they seem to like 35-36psi better than 32, my kumhos feel like rocks at 35 and great a 32
Old Nov 2, 2011 | 08:05 PM
pliskin8's Avatar
falken ziex ze 912
Old Nov 2, 2011 | 08:10 PM
98civdx's Avatar
Master Detailer
I ran my falken's between 32-35psi.
Old Nov 2, 2011 | 08:16 PM
pliskin8's Avatar
sounds good
Old Nov 2, 2011 | 08:34 PM
I say keep it at 35 and watch for wear in the center of the tire or if it seems to lose traction in the wet easily drop it down to recommended pressure and re assess
Old Nov 2, 2011 | 10:02 PM
B16B Four Door's Avatar
I work in a tire shop and put 35 in tires all day long. Like the others I'd say 32-35 is a good psi to be running
Old Nov 2, 2011 | 10:13 PM
Humphrizzle's Avatar
it is dependent on the weight of the car as specified in the owner's manual. just because the tire profile and wheels are different, doesn't change the weight specifications of the tires.
Old Nov 2, 2011 | 10:14 PM
Rvkeg6's Avatar
on mine is like 42 max so i do like 38
Old Nov 3, 2011 | 10:44 AM
i bet your tires go bald easily.
Old Nov 3, 2011 | 10:56 AM
TunerN00b's Avatar
This is correct.
Always use the manufacturer's recommended pressure as a starting point, and adjust in small increments based on wear and driver preference (assuming the driver is knowledgeable enough to make that call).
Old Nov 3, 2011 | 10:58 AM
thenext's Avatar
20% cooler
I run on stock 13" tires inflated to 36 psi as recommended on the sidewall.
Old Nov 3, 2011 | 11:00 AM
42 max posted on the tire? this means after 42 psi, it will fail (explode). Read my previous explanation
Old Nov 3, 2011 | 12:14 PM
TunerN00b's Avatar
Sidewalls don't have a recommendation for pressure.
They have a max pressure the tire has been tested to be capable of holding when run at the max weight load they are rated for.
Running tires at their max pressure will generally result in uneven wear (center section wears faster), increased stopping distances, and reduced comfort, though they will be a little more resistant to hydroplaning.
Old Nov 3, 2011 | 09:44 PM
Bix VT's Avatar
When I had those falken ziex's, I ran 35psi. I tried 30 and 38, but it just didn't grip as well in the corners, and I never got uneven wear at 35, so that's what I would reccomend.
Old Nov 3, 2011 | 10:01 PM
Texas4door's Avatar
Since it's getting colder, I'd recommend 35 instead of 32, that way when the temp does fall, you won't have to keep getting your tires aired up when the pressure falls.
Old Nov 3, 2011 | 10:38 PM
vinem1's Avatar
interesting info......
Old Nov 3, 2011 | 10:39 PM
vinem1's Avatar
Interesting info
Old Nov 4, 2011 | 05:10 PM
pliskin8's Avatar
good info, think i'm gonna keep it at 35psi
Old Nov 4, 2011 | 05:18 PM
Lugzilla's Avatar
Canuckian
I keep the civic pressure at 34f,35r and the prelude at 36 all round. This is through many thousands of kms of driving and experimentation. This is what I find works best for me and my driving habits, experiment a bit and find out what works best for your preference.
MyBigNut
Dec 14, 2002 06:54 PM
dvp95
Nov 4, 2002 09:15 AM
Veil_Side_
13
Feb 2, 2002 05:34 PM
99ls
Jul 26, 2001 03:16 PM
