Need some repair input advice...p1129 code thrown.
Old Nov 2, 2011 | 06:51 PM
LunarEclipse's Avatar
Default Need some repair input advice...p1129 code thrown.
Im working on a 99 integra LS with a code 1129 coming up on the scanner and ive tried the following and nothing has worked:
Cleaned the IACV/ made sure its plugged in
replaced the map sensor
cleaned the throttle body
checked for vacuum leaks
plugs are all plugged in
It ran fine before we switched out the old manifold to a skunk2 manifold, but afterwards it ended up pitching out codes.
Car has the following syntoms:
idles spiratic
runs to about 3k and then has instant loss of power, then regains power
runs rich
misfires hesitantly when it wants
On a side note, it had a bad oxygen sensor bank 1 that we replaced due to coolant spilling on the old one so we bought a bosch plug n play sensor to replace it. If you have any logical suggestions, id really appreciate it. Thanks
Old Nov 4, 2011 | 12:43 AM
Default Re: Need some repair input advice...p1129 code thrown.
found the solution, ended up being a major vacuum leak at the throttle body so the map sensor was reading high volume of air intake. A new TB gasket and she runs like a champ.
Demonvw
Honda Civic (2006 - 2015)
Jul 1, 2018 09:30 AM
jdmacuraITR
Jul 28, 2014 06:06 AM
Gabe Gamble
Aug 7, 2011 03:26 PM
Kidnkorner
28
Jun 26, 2010 03:40 PM
TRYLSTEG808
May 28, 2007 07:40 PM
