Got a lil water or coolant on my oil cap
Old Nov 2, 2011 | 04:36 PM
si-ej1's Avatar
Default Got a lil water or coolant on my oil cap
got water or coolant on my oil cap should i jus wait to see if i get alot more on it before i try to change the head gasket or is it jus moisture becuZ its getting cold outside
Old Nov 2, 2011 | 04:42 PM
slowturbocx's Avatar
Default Re: Got a lil water or coolant on my oil cap
Do you let it warm up all the way? A little is normal, a lot....start pulling the head.
Old Nov 2, 2011 | 04:43 PM
si-ej1's Avatar
i start the car take my wheel lock off and drive i jus checked the cap and its gone
Old Nov 2, 2011 | 05:07 PM
redm3turbo's Avatar
change the oil...before you yank off the head....
Old Nov 2, 2011 | 05:23 PM
hondatuner34602's Avatar
there are certain ways to go about it to see if your head gasket is blown. One do a block test where you test to exhaust is coming through your radiator filler neck. Two check your oil and see if it looks "milky" signs of water is gettin in/blown head gasket. Third do a complete compression check on all four cylinders hope that helps you out.
Old Nov 2, 2011 | 06:16 PM
si-ej1's Avatar
thanks ill do that
nicknack25
Nov 28, 2010 04:52 PM
djviet2000
23
Apr 29, 2008 09:36 PM
A Tribe Called Honda
Feb 21, 2008 03:19 PM
stripery2bk
Apr 17, 2006 05:44 PM
tek_civic
Feb 16, 2006 06:43 PM
