D4 Light Flashing in 99 Accord- P0758
I just put in my new trans and besides a bad leak at the passenger side axle shaft the trans is throwing the code P0758 which seems to be a solenoid.
It also set off D4 to flashing. Car drives fine mostly except it wont catch when taking off-almost as if I had a clutch and it was burnt, pretty much have to rev to 4k to move.
Once going 2nd to 3rd gear is hard but it moves fine after that.
Can anyone shed any light on the code?
one of your shift solenoids is either bad or disconnected. i usually start with taking them off and cleaning them out and see if that works to clear the problems up. also make sure they are plugged in while doing all this.
You mean actually take the solenoid out and clean it right? Not the connector. What are you cleaning them off with. Also when testing for continuity what should they read?
ajparry89
Apr 24, 2018 07:04 PM
maxmrgn
May 23, 2016 01:29 PM
Proficio
Sep 17, 2002 01:05 PM
