92 Civic LX 5-speed -- Vaccum Leak?
Old Nov 2, 2011 | 09:17 AM
UniqueX707's Avatar
Icon2 92 Civic LX 5-speed -- Vaccum Leak?
Well cleaned my IACV yesterday cause it was idle at 300-500 now since i clean it and it idles at 1500-1800. And I made sure i made sure i tighted it very well and i having a feeling its a vaccum leak but can find it! My car is a 1992 Civic LX D15B7 OBD1 5 speed
Old Nov 2, 2011 | 09:32 AM
thenext's Avatar
20% cooler
Default Re: Vaccum Leak?
Take a good look at your IAC valve and that area. Make sure you put everything back on the right way and that you didn't knock off a vacuum line somewhere.
Old Nov 2, 2011 | 09:56 AM
UniqueX707's Avatar
Well im pretty sure i didnt I just took out the two blots to remove it and the 2 hose lines but i clicked the line back on!
Old Nov 2, 2011 | 10:00 AM
thenext's Avatar
20% cooler
Pretty sure isn't 100% Get in there and make sure everything in that area is connected.
Did you make sure the IACV gasket didn't fall out? It looks like a little figure 8.
Old Nov 2, 2011 | 10:08 AM
Steezer's Avatar
spray some brake or carb cleaner on the seams of the iacv to find a vacuum leak. If you spray the cleaner on a vacuum leak the idle will go down for a quick second and go back up. You might need to seal it. Also fot the hoses put vasoline inside them and slide them back on. it will help make a better seal.
Old Nov 2, 2011 | 12:47 PM
Former User's Avatar
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Nov 3, 2011 | 08:42 AM
UniqueX707's Avatar
I add a bit more stuff thank you
arziffel
Feb 17, 2012 07:06 PM
steelhitman1245
Nov 23, 2011 12:30 PM
DA3
Sep 6, 2008 09:40 PM
Vtak DOHCTA
Dec 12, 2005 06:18 AM
