First attempt at TIG
Old Nov 2, 2011 | 05:57 AM
TrueStreetVW's Avatar
Default First attempt at TIG
Just wanted to get some opinions on my first attempt at tig welding. Machine was set on 120amps welding 1/4 inch thick flat bar. #7 gas cup Argon flow around 12 l/min. Here is the outcome. Feedback?
Old Nov 2, 2011 | 03:54 PM
hoochhenry's Avatar
Default Re: First attempt at TIG
Doesn't seem to be fused enough but looks well
Old Nov 3, 2011 | 12:40 AM
dohc_star's Avatar
I would try getting a little more heat and see what happens just my .02
Old Nov 3, 2011 | 02:12 AM
Here is my 2nd attempt. 230amps
Old Nov 3, 2011 | 02:26 AM
hoochhenry's Avatar
Looks perfect now
Old Nov 3, 2011 | 06:26 AM
SovXietday's Avatar
Heat on the 2nd looks much better. Not bad at all for a first timer.
Old Nov 3, 2011 | 07:13 AM
Walterronny's Avatar
230amp? definitely my doubs about amperage in USA and Europe are correct.
welds looks good.
Old Nov 3, 2011 | 07:58 AM
HellaFab's Avatar
its 1/4" bar.
it would take alot of heat to get them going... but 230 sounds like alot.
Old Nov 3, 2011 | 08:24 AM
I used millers tig calculator and that's about where it told me to be for 1/4 inch thick stainless. Thanks for the compliments fellas. I only have about an hour and a half total behind the shield so far.
Old Nov 3, 2011 | 09:11 AM
I just noticed I screwed up with my picture posting. The last picture was done at 200amps. This is the 230amp weld.
Thoughts?
Old Nov 3, 2011 | 10:21 AM
SovXietday's Avatar
Thoughts?
That makes more sense, your 230amp looks too hot. 200amp picture is pretty good.
Old Nov 3, 2011 | 02:14 PM
AReynolds91's Avatar
Not bad at all. 200 amps seems to be right on the money. Just keep at it, but for being less than 2 hours behind the shield....i give u mad props.
Old Nov 3, 2011 | 05:02 PM
Thanks guys. I know when I start welding stuff I give a damn about I need to clean the metal better but I really to appreciate all the comments.
LeegodaEG
Suspension & Brakes
36
May 22, 2013 02:08 PM
akcapr
Welding / Fabrication
26
Feb 9, 2012 09:35 AM
D-Rob
May 26, 2010 10:25 AM
The Destroyer
47
Feb 27, 2008 08:00 PM
boostdGS
Jul 18, 2003 05:59 PM
