93 honda civic SI D15B problems!!!
Old Nov 1, 2011 | 07:55 PM
roks94'HATCH's Avatar
Icon2 93 honda civic SI D15B problems!!!
I got a Honda Civic 93 Si With a D15B. Cell code 16... car takes a while to start, cranks then starts. once it manages to stay on, i'll start to drive, then gas pedal will loose power, gas pedal is all the way to the ground. pretty much floored. then the car jerks, goes and starts again to loose power. Drop it down one gear, then it will run again. Will run again for a couple of seconds... Again the pedal is all the way to the floor, like if i ran out of gas, then seems like it gets back gas goes then stalls.. need help.
Old Nov 1, 2011 | 08:02 PM
Former User's Avatar
Default Re: 93 honda civic SI D15B problems!!!
Resolder the main relay.
http://techauto.awardspace.com/mainrelay.html
Old Nov 1, 2011 | 08:11 PM
okay i'll try that..... what about just replacing the relay...
Old Nov 1, 2011 | 08:33 PM
Most people just recommend resoldering as buying a new main relay is more expensive.
Old Nov 1, 2011 | 08:55 PM
okay thanks..
Old Nov 4, 2011 | 07:34 PM
Icon6 Re: 93 honda civic SI D15B problems!!!
i just resolder the relay but still does the same thing. and still get CEL Code 16. i just bought a new relay off my work... but same problem..
Old Nov 4, 2011 | 07:55 PM
Dioxine's Avatar
Did this problem just occur out of the blue or is this a new build and you havent had it going at all yet. Maybe a bad fuel pump relay? Bad ecu ground? Its gonna be trial an error fix.
Old Nov 5, 2011 | 04:44 AM
it just occur out of the blue.. drove fine before.... got on the freeway to go to work. felt the car running weird but made it to work. going back home took a **** on me. had to tow it home.. change distributor same problem. did a spark test it all passed..
Old Nov 5, 2011 | 06:32 AM
With the key in ON(II), do the Yel/Blk wires in all 4 fuel injector clips have battery voltage?
Old Nov 5, 2011 | 06:35 AM
Dioxine's Avatar
I would install a fpr. Sounds like your fuel pump might have taken a **** on you. While they normally just go out its not unheard of for them to kinda putter along for day or 2. Try taking a rubber mallet and hitting the gas tank a couple times and see if it starts right up. If it does then its 99% your fuel pump.
Old Nov 5, 2011 | 06:41 AM
Neither a bad fuel pump nor a bad FPR would throw code 16.
Old Nov 5, 2011 | 06:45 AM
Dioxine's Avatar
I meant fpg. But your right I forgot about the cel.
Old Nov 5, 2011 | 09:34 PM
RonJ@HT okay i'll check them
Old Nov 9, 2011 | 02:30 PM
i got 10.4 ohms out of the injectors.... test all injectors power.. its all good their too. my next step is to check fuel pressure
Old Nov 18, 2011 | 06:54 PM
fuel pressure 44psi. found out thats it was my spark plugs....
Old Nov 19, 2011 | 05:33 AM
Measure voltage at each injector clip.
Old Nov 24, 2011 | 07:34 AM
took back the distributor that i just bought from my shop. got it warrantied out and bought spark plugs. Put them on boom car starts with no problems runs even smoother... re soldering relay helps a lot....
LarryDawn
Honda CR-V & Element
May 29, 2017 06:59 AM
DG19
Mar 6, 2011 04:39 PM
tstaud
May 20, 2008 12:03 AM
ls19integra95
Dec 25, 2007 04:58 PM
DmcL
Feb 4, 2007 10:29 AM
