Brake Light Switch Testing....
Old Nov 1, 2011 | 05:46 PM
KelvinR's Avatar
Default Brake Light Switch Testing....
Hey guys im kinda a noob here but how can I test a brake light switch a 96 accord? I know if it was the to pin one I can just jump it but just my luck its a 4 pin wire.
I want to check it because my brake lights arent turning on at all and I cant shift out of parking for some reason.
Old Nov 1, 2011 | 05:49 PM
SL33Pr_ProjeK's Avatar
Default Re: Brake Light Switch Testing....
glue a dime to the brake pedal and be done with it.
the switch is most likely not broken, stick your head down there and find out.
Old Nov 1, 2011 | 06:25 PM
KelvinR's Avatar
Thanks for your help but I already got down and took the brake switch off hence the (how to test a brake light switch) but its a 4 pin connector so it got me a bit confused
Old Nov 1, 2011 | 06:44 PM
is the switch actually broken? when you push the little button what happens? were your breaklights stuck on with no keys in the ignition?
ive had this problem on a 92 prelude and 97 accord, both times it was just this little tab that falls off the pedal after a while.
silly, if you ask me.
Old Nov 1, 2011 | 07:06 PM
KelvinR's Avatar
Bro I tried to be nice the 1st time but you need to read what I write before replying with random things. The switch isnt broken in the outside but might be in the inside.
Old Nov 1, 2011 | 08:26 PM
nus_dogg's Avatar
Only if Im at work, I'd be able to tell you what color wire is the input wire and what the output would be.
Old Nov 2, 2011 | 09:55 AM
KelvinR's Avatar
Thanks but to make things worse the harness burned lol my dad decided to put a bigger fuse and instead of the fusing breaking the cables did. just my luck. So now I need to find out where those 4 cables come from. I followed it to where it meets the all the cables but then splits right above the inside fuse box.any idea where it leads to?
Old Nov 2, 2011 | 10:15 AM
BigJohnCD5's Avatar
i had the same problem as SL33pr and a beer bottle cap and some duct tape fixed my problem. then again, i only buy cars with manual gear boxes..
Old Nov 2, 2011 | 11:07 AM
KelvinR's Avatar
Ok so ive read and read and found out that my stoplight switch is always getting power on one connection but which one of the 4?
also I read that the other 3 go to the fuse panel under the dash but I dont know where exactly. I know its a green white cable but there are just so many lol This is the panal Name:  FuseBox.jpg
If I can just hook up a positive and a negative and not use the cruise control connections I think it should work. where are my honda experts! lol I hate electric diagrams
Old Nov 2, 2011 | 07:55 PM
danram76's Avatar
Drum or Disc for REAR breaks on a 1997 4door Honda Accord EX ?
Old Nov 2, 2011 | 08:22 PM
nus_dogg's Avatar
Wrong thread to be asking this. Check the thread you made, I post up the answer to that.
Old Sep 10, 2012 | 02:38 PM
Omar Zaldivar's Avatar
Did you solve it??.....same thing happened to me on my 97 accord, i had a short circuit now the stop light in the dashboard won't go off, all bulbs are fine, new sensor, fuses OK and don't wanna waste money on a switch without testing it first.
thanks
XTYPES
Jul 4, 2009 03:31 PM
geneva
Jun 11, 2008 05:46 PM
PREACHERBREW
Jun 5, 2008 03:47 PM
haz19
Oct 23, 2005 01:14 PM
