Em1 code p0133 help
Hey guys I'm new to the forum but have been lurking around for awhile. I recently purchased a 2000 Civic Si and after about a week of driving it the cel came on and the code was p0133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1) Both o2 sensors have recently been replaced, and I think it would be a wasted of money to go and buy another new one without seeing if its another problem. I was wondering what I should Troubleshoot, I have searched the forum and googled it and really am still in need of help. Any help would be greatly appreciated! Thanks!
The sensor has just been replaced with in the last 2000 miles, Thats why it is weird that it is going off, Is there anyway to check the wiring between the o2 and the ecu? Thanks for the help so far everyone
Some brands of fuel and/or fuel additive packages may create deposits at the fuel injector tips. This build-up may cause slight air/fuel deviations between each cylinder. Build-up of deposits, when coupled with very specific driving conditions, may cause the MIL to come on and the PCM to store DTC P0133.
check the wiring to the sensor, check the molex connector itself.
By the way what brand did you use?
and you are sure you have the right part number?
Also, did you reset the computer, did it come back?
does the car have the stock engine?
Now that code doesn't come back on anymore and the p0135 comes on so I went out and bought and o2 sensor from autozone reset the code and the cel comes on almost right after I reset the code with the obd2 scanner and the live data says its running so rich that it pegged the volts at the meter at 1.275 I'm really not sure what to check
Thanks guys will try those things, reguardless of that today I took it to the local strip with some friends and ran a 15 flat in it, I was shocked, stock b16 i/h/e with mounts and p/s delete wasnt expecting that at all hopefully going to get an ecu soon to see what it'll do with a good tune and 2 step. Thanks for all your help
RVCA97
Dec 28, 2005 09:24 AM
