How much oil do you guys burn?
Old Oct 6, 2002 | 03:00 PM
pelotudo's Avatar
Default How much oil do you guys burn?
Installed the turbo ~2k ago. Changed the oil over to Castrol Syntec 10w-30. Since the install, I have put in 3/4 of a quart. I am getting ready to change it this week sometime. Is this normal, or am I burning too much?
jB
Old Oct 6, 2002 | 03:04 PM
inspyral's Avatar
Default Re: How much oil do you guys burn? (PelotothamuthafreakinTudo)
I don't seem to burn any oil at all. I use Mobil 1 synth 10w30 and put in 4qt each time and it never goes below the top mark on my dipstick.
Old Oct 6, 2002 | 03:20 PM
modvp's Avatar
Default Re: How much oil do you guys burn? (inspyral)
i burn approx 1qt every 5000 miles of hard driving.
Old Oct 6, 2002 | 03:28 PM
b18b98's Avatar
Default Re: How much oil do you guys burn? (modvp)
knocking on wood, but i never burn oil either.
Old Oct 6, 2002 | 03:52 PM
turbo sol's Avatar
Default Re: How much oil do you guys burn? (b18b98)
192,000 and no oil burning here, (rebuilt head though) boosting for a while too.,
Old Oct 6, 2002 | 03:58 PM
skilzz's Avatar
Default Re: How much oil do you guys burn? (turbo sol)
no oil burning, check your oil return line and your oil inlet for leaks, PM me if anything
Old Oct 6, 2002 | 07:40 PM
roydogg's Avatar
Default Re: How much oil do you guys burn? (maddskilzz)
i burn about a quart aweekend runnin hard about 10 to 15 races. I know that it's not the seals just got that replaced so probaly the piston ring. Just gotta do a compression test to find out.
Old Oct 6, 2002 | 07:52 PM
smoothludey2's Avatar
New User
Default Re: How much oil do you guys burn? (roydogg)
i burn about a quart every 2000 miles, if i boost hard....my car was burning oil before i went FI tho...it's the H22 curse.
Old Oct 6, 2002 | 07:59 PM
PrecisionH23a's Avatar
Default Re: How much oil do you guys burn? (smoothludey2)
the more you boost the more you burn
Old Oct 6, 2002 | 08:36 PM
avividmemory's Avatar
Default Re: How much oil do you guys burn? (GudeH23a)
id say check the lines first off...i was leaking a little due to a bad connection on the feed line...other than that it doesnt seem to burn...just runs really rich
Old Oct 7, 2002 | 05:34 AM
modvp's Avatar
Default Re: How much oil do you guys burn? (SpoolinLS)
i have my valve cover breather venting back into the turbo (after the filter but before the compressor). In the past, I had a filter there (on the valve cover) and in that config. it did not burn oil.
210jdmgsr
Aug 15, 2007 03:55 PM
SOHC_MShue
Jul 25, 2005 10:36 AM
oMek
Mar 2, 2004 07:25 PM
HybridGSR1
Jul 4, 2003 07:37 AM
boostcontroller
Jun 27, 2003 06:53 AM
