starting my mock up on my turbo manifold
Old Nov 1, 2011 | 12:04 PM
hoochhenry's Avatar
Default starting my mock up on my turbo manifold
just tacking up a few bits on the manifold should have most of it done tomorow [IMG][/IMG]
Old Nov 1, 2011 | 09:00 PM
AdReNaLiN's Avatar
Default Re: starting my mock up on my turbo manifold
Not a lot of room for the othe runners... good luck!
Old Nov 1, 2011 | 11:48 PM
FredC's Avatar
The fitment looks awesome! How are you going to route runners 2 and 3? For ease of installation and closest way to equal length I would assume you'd probably want to take 1 and 4 and move them to the back.
Old Nov 2, 2011 | 01:41 AM
hoochhenry's Avatar
ive plenty room hopefully iget to put the final pices together today il post some pics up cheers
Old Nov 2, 2011 | 04:13 AM
HellaFab's Avatar
he could always make it a ramhorn manifold and have TONS of room from the other angle.
Looks good.
cheers.
Old Nov 2, 2011 | 07:08 AM
SovXietday's Avatar
Looks like he'll probably go under 1 and 4 and come up from the sides like a ramhorn.
I can't tell from where I'm looking now, but is the number one runner fitted properly to the elbow coming off the flange?
Also, is it just me, or are the ports on your head flange REALLY small?
Old Nov 2, 2011 | 07:16 AM
that-guy's Avatar
i don't think he can snake 2 and 3 under 1 and 4 as it may hit the turbo...regardless, 1 and 4 should have gone onto the other two ports on the collector IMHO
and your right Sov, those head flange ports do look really small for some reason
Old Nov 2, 2011 | 05:41 PM
hoochhenry's Avatar
[IMG][/IMG]
Old Nov 3, 2011 | 12:56 AM
Boosted_B_Series's Avatar
Looks good man! Looks like you have great fitup
Make sure, that you bolt the head flange (or any flanges) to a head (turbo, gate, matching flange), or chunk of metal when you do your final solid welds. If not it will warp to ****. My first manifold I didn't, it took the machine shop over 2 hr to fix it. Now I use old heads, no problem with warping.
Old Nov 3, 2011 | 01:43 AM
hoochhenry's Avatar
will do I've an old head and turbo ready for when I start to weld ,il ne drilling out for an external wastegate also ,thanks for the input guys,and the helpful hints
Old Nov 3, 2011 | 01:52 AM
RickyLee53's Avatar
A starlet manifold, we make tonnes in a similar way. You just need bigger preps, especially on the collector.
Old Nov 3, 2011 | 02:00 AM
hoochhenry's Avatar
Yes Ricky seen some of your stuff must say it the best around,friend of mine made a manifold on the same spec as the one I'm doing here he made 370 Bhp on the same manifoldneeds a bigger turbo to push for more manifold is doing the job perfect as in flow wise
Old Nov 3, 2011 | 04:13 AM
RickyLee53's Avatar
Yes, I did some flow testing on one of ours and it'll flow 600hp without problems.
Where are you based?
Regards
Ricky
Old Nov 3, 2011 | 04:59 AM
hoochhenry's Avatar
Regards
Ricky
im living in Ireland
Old Nov 3, 2011 | 05:52 AM
bcumbie's Avatar
Looks good.
Old Nov 3, 2011 | 02:36 PM
hoochhenry's Avatar
heres and update coming along fine must say not to bad for my first manifold [IMG][/IMG]
Old Nov 3, 2011 | 06:37 PM
welfarepc's Avatar
solid work!
Old Nov 3, 2011 | 06:38 PM
dschenke's Avatar
good work need better pics tho plz
Old Nov 3, 2011 | 11:05 PM
RadekSkylark's Avatar
As far as mock-up/prep goes - nicely done! Looks really great!
Good luck!
Old Nov 4, 2011 | 10:03 AM
hoochhenry's Avatar
il put better pics up when i get a chance to weld it want to fit it up to the car just to double check
Old Nov 4, 2011 | 02:43 PM
hoochhenry's Avatar
just a few mild steel bends for another manifold il be doing mybe a close ramhorn style one
[IMG][/IMG]
Old Nov 7, 2011 | 09:40 AM
SpeedwayCoating's Avatar
looks good
Old Nov 7, 2011 | 09:54 AM
Slim1320racing's Avatar
Real nice bro
Old Nov 7, 2011 | 06:51 PM
Golfball's Avatar
looks like a nice solid manifold man, keep the pics coming.
Old Nov 10, 2011 | 01:36 PM
hoochhenry's Avatar
just doing another manifold mocking up still waiting on some mildsteel flanges to be made just sitting aganist the stainless flanges lol [IMG][/IMG]
