Eg, rear brakes integra 90-93 update ep3?
Old Oct 31, 2011 | 11:21 PM
Alucard-1524's Avatar
Default Eg, rear brakes integra 90-93 update ep3?
Hi frend, I need technical help. I have an EG hatch (95), in the past had put an integra rear brakes 90-93. I want to do an update on the brake system, I will not put a brembo (wish I could) I was thinking of putting the swap with CRV front calipers and ventilated rotortes. and rear, adapt Ep3 brakes with ventilated rotors 2002-2003, my technical problem is if I can I install EP3 rear brakes on a integra 90-93 rear brakes? Or this swap only works in a integra 94-01 and si 99-00 brakes. You can help me to improve my braking system than other things I can improve. thanks
Old Nov 1, 2011 | 06:02 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Eg, rear brakes integra 90-93 update ep3?
EP doesn't have ventilated rear discs. No FWD does.
Here is a how-to from the Integra forum: https://honda-tech.com/forums/acura-integra-6/ep3-dc5-10-2-rear-disc-brake-upgrade-94-01-integras-1110005/
Old Nov 1, 2011 | 07:26 AM
94eg!'s Avatar
#1 Super Guy
Loved
BTW: I found this on D-series.org:
http://www.d-series.org/forums/diy-f...e-upgrade.html
If you already have rear discs, it looks like the only thing you need to put 10.2" rear brakes on is the following:
- 02-03 Civic Si Rear Rotors (these 4x100)
- 02-03 Civic Si/RSX rear caliper brackets
- 02-03 Civic Si/RSX/ITR rear brake pads
You just reuse your old caliper with the new caliper bracket and everything bolts right up. Pretty cool if you ask me. Of course this will add rear brake torque so be sure to test everything to the extreme to make sure your rears don't lock first.
Old Nov 1, 2011 | 04:58 PM
Thanks
JDM_NANO
Northeast (Sales)
Oct 12, 2011 06:57 AM
crazy irishman
Oct 14, 2009 11:32 PM
jxhxb
Oct 6, 2007 03:53 PM
