RO_SUNNY's Garage!
Old Oct 31, 2011 | 11:02 PM
RO_SUNNY's Avatar
Default RO_SUNNY's Garage!
Hi everyone.
After a couple of months that I asked all sorts of stupid questions to everybody I have finally decided on the tools that I need for my shop and bought a few as it follows.
-6'' X 78'' belt sander with an 4 kw electric motor (5.4 horse power :O)
-Big band saw 14'' X 8'' with an 0.75 kw electric engine (1 horse power)
And.................1.5 horse power polishing machine
I was just like a kid on Christmas evening
Thanks Collin, Markku and also you Reinins for the advices and also for answering all my questions
Old Nov 1, 2011 | 02:00 AM
hoochhenry's Avatar
Default Re: RO_SUNNY's Garage!
some nice machines there good luck with it lad
Old Nov 1, 2011 | 02:31 AM
RadekSkylark's Avatar
Looks like you've bought some nice tools for yourself Put them to work!
Good luck!
Old Nov 1, 2011 | 03:53 AM
ToxicFabrication's Avatar
OG Fabricator
Very nice selection of tools, looks like you listened when I've mentioned not slacking on tools.
Good luck to ya.
Collin
Old Nov 1, 2011 | 05:33 AM
RO_SUNNY's Avatar
Thanks everybody.
Yeah Collin I have thought alot before buying them ....and of course I listened to each and every advice you gave me ( and also some others ).
Thanks again!
Old Nov 1, 2011 | 11:40 PM
RO_SUNNY's Avatar
Collin please tell me ....
What polishing wheels are you using for the mirror finish on the pipes/elbows?
P.S.
I am saying about the wheels for the polishing machine
Thanks.
Old Nov 10, 2011 | 10:16 PM
RO_SUNNY's Avatar
So..............have been busy lately with a Honda D16 manifold.
The manifold is intended to be a low budget model with a mid performance range.
It's low budget because it will be made out of 1 1/2'' sch 10 mild steel steam pipe/elbows, and it's mid performance because of the volume and the design.
Many thanks to Collin, Markku and the other which made alot of helpful threads.
Welded the collector 2 by 2
Made a small bevel to have a full penetration weld ( it came pretty good I must say)
After that I grinded of some bits from the insed and welded it completly.
And this is how it was finished (the collector)
Sorry for the bad quality phone pics!
More to come these days.
Old Nov 11, 2011 | 05:30 AM
SpeedwayCoating's Avatar
nice equipment you bought. what kind of welder do you have?
Old Nov 11, 2011 | 05:35 AM
RO_SUNNY's Avatar
It's an Morell welding 315 amp ac / dc tig welder with pulse/Hf.....everything you need for welding anything.
They are actually assembled in my city, but they are partly made with chinese parts (but what's not chinese nowadays ).
Old Nov 11, 2011 | 07:09 AM
Agtronic's Avatar
Very nice tools. The belt sander looks really great! Good luck with everything!
Old Nov 11, 2011 | 01:03 PM
RO_SUNNY's Avatar
Thanks Markku!
How is your life going around?!?!
Old Nov 14, 2011 | 10:02 PM
RO_SUNNY's Avatar
Coming along with the low budget manifold.
As you can see it tends to be a miniramhorn
Sorry for the S&^%T camera pictures.
Old Nov 15, 2011 | 10:40 PM
RO_SUNNY's Avatar
Oki doki.................
So....basicly I finished the manifold ( I just have to finally weld the last 2 runners)
The gap looks kinda big but it's only 1mm wide (the 1.6 mm filler rod doesn't enter inside that gap)
Old Nov 16, 2011 | 09:50 PM
FabChild's Avatar
lookin good man
Old Nov 16, 2011 | 09:55 PM
RO_SUNNY's Avatar
Thank you very much!
Old Nov 17, 2011 | 04:20 AM
HellaFab's Avatar
Looks good.
I would have scrapped the straight peice with the gap and redone it. Thats where you loose all of the strength. At least do two passes to lay the filler on thick and make sure it fuses in both pipes if you decide to use it. (Im sure you know this, your welds look good)
Cheers,
Matt
Old Nov 17, 2011 | 04:59 AM
RO_SUNNY's Avatar
Thanks Matt,
But it ended with 100% penetration on that one.....and the root looks quite good after wedling it. If the penetration wouldn't go well I would have change it.
Cheers,
Bogdan
Old Nov 17, 2011 | 06:22 AM
HellaFab's Avatar
You can get visible penetration with gaps as the filler is filling the gap. That doesnt mean that there is good fusion with the penetration.
Sorry i didnt have my coffee yet when i posted that. Having not seen the finished part i was just making an open comment.
Cheers,
Matt
Old Nov 17, 2011 | 10:26 PM
RO_SUNNY's Avatar
Job completed.
manifold came out better than I have expected:
Penetration pics:
Next to come is porting, sandblasting and then heat coating (850 Celsius degrees resistant)
Cheers,
B
Old Nov 18, 2011 | 04:50 AM
OG Fabricator
Turned out great sunny. Keep it up
Old Nov 18, 2011 | 05:19 AM
RO_SUNNY's Avatar
Thanks Collin,
I couldn't have done it without your advices!
You helped me alot and so the other guys who adviced me!
Cheers,
Bogdan
Old Nov 21, 2011 | 01:23 PM
Race Egr's Avatar
That belt sander is ****in legit. I want one.
Old Nov 21, 2011 | 09:55 PM
RO_SUNNY's Avatar
That is exactly what I said when I saw it
Thanks
Old Dec 13, 2011 | 02:34 AM
RO_SUNNY's Avatar
Custom water radiator for a Turbo'd Honda CRX
Old Dec 13, 2011 | 04:41 AM
hoochhenry's Avatar
nice work loving that manifold ,cant wait to see some more keep up the good work
