Power Window Problem. NEED HELP!PLZ!
Old Oct 31, 2011 | 03:49 PM
EnviedByMany's Avatar
Default Power Window Problem. NEED HELP!PLZ!
Well, desperate to fix the problem that i am having with my
94 accord but cant really point a finger at what it is.
I cleaned the plugs, My controls for the windows arent fried,
checked my relay seems perfect.
So My front driver and passenger side windows will roll
down but not up. just changed out my front driver side window
regulator and still have a problem with it. Ive rolled down
my windows and they are stuck down so i really dont want anything
stolen so feedback would be AWESOME. thanks all of you on honda tech
that makes working on my honda a lil bit more easier
Old Nov 1, 2011 | 02:36 PM
Default Re: Power Window Problem. NEED HELP!PLZ!
So, i went to pick a part to get different switches for the windows and its the same problem. if the passanger side motor doesnt function will it make both front windows not work properly?
Old Nov 1, 2011 | 05:18 PM
liveinspired's Avatar
check the rails maybe the rubber is binding. try helping thw mindow with your hands as u push up and see if it helps
Old Nov 1, 2011 | 05:52 PM
SL33Pr_ProjeK's Avatar
check to make sure youve got good clearance between your window and any wires you might have floating around in your door. i had to tuck my window motor wire un-naturally around the motor itself. this is also partly because i installed a passenger side motor in the driver side door...but just sayin.
jessihall
Sep 6, 2010 11:45 AM
jdmferiodrvr
Feb 23, 2009 08:32 PM
oldskoolDA6
May 2, 2008 05:45 AM
Lostmind004
Nov 22, 2005 12:58 PM
