Eratic Heat in 89 si , 10 bucks to who can figure it out
Old Oct 31, 2011 | 01:44 PM
93grayeg's Avatar
Icon3 Eratic Heat in 89 si , 10 bucks to who can figure it out
I have a 89 si with a b20b swap, I replaced the thermostat last year with a oem honda one. car has a pwr radiator with a new skunk2 radiator cap. Heres the deal. The car was blowing hot heat fine untill we just recently got really cold weather , Now when I drive it it will blow cold, then start blowing hot out of no where, It will blow hot for a little, then back to cold. today I bled the coolant system and it seemed to help but it's still acting crazy. Could that oem thermostat of went bad already? I will gladly pay pal 10 bucks to whoever figures this out
Old Oct 31, 2011 | 01:47 PM
vtecn8ive's Avatar
Default Re: Eratic Heat in 89 si , 10 bucks to who can figure it out
Check fluid levels
Flush heater core
Do you smell coolant at all? Any crystallization near your feet? How old is your water pump? Check to see if it's coming out of the weep hole.
Old Oct 31, 2011 | 01:56 PM
93grayeg's Avatar
Originally Posted by vtecn8ive
Check fluid levels
Flush heater core
No coolant smell, coolant level stays full, motor has 45k miles on it, I never changed the water pump. Car does not over heat and the temp guage stays where its supposed to.
Old Oct 31, 2011 | 02:23 PM
green91's Avatar
Need to do a block test on it, see if you've got a blown HG thats allowing exhaust into the coolant system, and therefore air into your heater core. That or else youve got an ultra stubborn air pocket.
Old Oct 31, 2011 | 02:37 PM
4drEF's Avatar
Keyboard Humorist
Sounds like your heater core is working since you do get a bust of hot every now and then.
I think it would be odd to get any heat at all if you had a complete clog.
A partial clog would just be less efficient, but not erratic.
My guess is that your radiator is maybe a little too efficient.
Since it's cold outside, maybe the water in the radiator is getting too cold.
The engine water heats up to open the thermostat and allows the cold water from the radiator through the thermostat.
Being such cold water, maybe it closes the thermostat really fast.
Try blocking off half the radiator with some cardboard?
Old Oct 31, 2011 | 03:33 PM
kranked91dx's Avatar
I think you should get a look at the proportioning valves on the heater line, near the firewall, where the coolant hose enter into the cab to the heater core.
make shure the buterfly work's according to the control of the thermostat in the dash,
the butterfly may be loose or the plastic arm broken and it disturb the flow of hot water to the core, making erratic hot/cold blowing.
just a thought...
Kranked
Old Oct 31, 2011 | 03:39 PM
zrickety's Avatar
Do this and let us know if it works
Old Oct 31, 2011 | 05:29 PM
93grayeg's Avatar
I will give this a shot and let you know, last week when it was about 50 Deg. outside my car would start blowing warm arm before the temp guage even went up. Now it goes the whole way to normal and still blows cold. Ill give it a shot though
Old Oct 31, 2011 | 05:31 PM
93grayeg's Avatar
just a thought...
Kranked
Ill check it out also, not exactly sure what your talking about though?
Old Nov 1, 2011 | 09:23 AM
Geemac's Avatar
I think the problem is located either in heater hose valve (fwd of the firewall) or the air diversion door under the dash.
When you turn the temp control dial on the climate control it pulls (or pushes) on 2 cables. 1. the heater hose valve and 2. air diversion door.
PM me your number, I'll talk ya through it.
Old Nov 1, 2011 | 12:26 PM
TearSDMF89dx's Avatar
^he is probably right...i had a very similar situation mine was the "air diversion door" in combo with a leaf and bug filled evaporator core
Old Nov 1, 2011 | 02:22 PM
93grayeg's Avatar
Explain^
Old Nov 1, 2011 | 10:19 PM
93grayeg's Avatar
Just a little update, today was about 50deg. Outside and the heat was blowing fine, im thinking 4dref was right , im going to try to cardboard thing tommorow, its supposed to be pretty cold. If it works , 10 bucks for 4dref
Old Nov 2, 2011 | 04:31 AM
evap core was limiting air flow to the heater core and the diversion dorr was half bypassing the heater core like the a/c was on
Old Nov 2, 2011 | 07:08 AM
4drEF's Avatar
Keyboard Humorist
But that would be like that ll the time.
The flapper wouldn't be opening and closing randomly, would it?
Old Nov 2, 2011 | 09:34 AM
j3wman's Avatar
buy a sunggie call it a day. wheres my $10
Old Nov 2, 2011 | 09:46 AM
no the door was stuck in the middle but with the restricted airflow it made the air swirl funny in the heater box causing it to intermittently go hot or cold
corince06
Jun 11, 2008 12:48 PM
Gvis420
Oct 21, 2007 05:42 PM
Gvis420
Oct 20, 2007 02:37 PM
Cashis Lee
Apr 28, 2005 04:29 PM
ThaSpitefulWun
Apr 5, 2004 09:17 AM
