OEM IAC or OE IAC and other questions???
I may be needing a new IAC and am wondering if this would be one of those parts that you want to go OEM on. The AdvanceAuto one is $175 and the Honda $295. Also was wondering if I should clean the Idle Adjustment Screw before I attempt to determine it's the IAC. Also I know inshould check for vac leaks, is carb cleaner the best option for this? Last but not least I know I may need to check the ECT if anyone could provide me with a link I'll be golden. The vehicle is a 2000 Honda Civic Si B16A2 with a CAI. Thanks in advance!
Yes and Yes! Code is P0505. Secondly if the car is cold it idles and drives fine if I continue to drive it without really stopping it's fine but if I stop chances are it will start acting up. By acting up I mean the idle immediately jumps to 1500 and under any type of throttle it is very jerky and rough. Once above a certain RPM it acts better but falls very hard once releasing the gas. If I turn the car off for 5-10 minutes or so and restart it then it's fine but is possible to act up once again if I stay stationary to long.
[QUOTE=Turpid Porpoise;46272336]What makes you think its the IACV?
Yes you should clean it before you buy a new one.
Carb cleaner is great for finding vac after the cleaning should the idle be adjusted to 700RPM while the car is acting up or acting normal, I'm thinking normal right?
A bad IACV is only one cause for P0505. What happens to the idle speed if you unplug the IACV?
Also do this:
Turn the engine off when it is hot, unplug the 2-wire ECT sensor under the distributor, and measure the resistance across the two terminals of the sensor. It should read 200-400 Ohms.
Also do this:
Also do this:
Also do this:
I will also check the ECT and if it reads abnormal is it safe to say it's that
So to test these does the car need to be acting up or no because if I leave the car off for a while upon restate it acts normal. So will the IAC still test bad, probably not right?
Hey Ron if I put the multimeter on the 2K setting I get a constant reading of .333-.336 does this sound right or do I need to be on different setting. It seems if I'm on a different setting it's hard to get a good reading n
Yeh I tried that and it flashes high 100's at times like 186 but goes back to 1 quickly after. Is it the plug right below the Vtec solenoid or is it the green plug that goes into the solenoid. It the one under correct because it is mated with the engine head.
Just unplugged the IAC while it was running normal it bogged down and then when I plug it back in it idles a little higher.
Ok forget my last post co poetry unplugged the wrong thing I didn't unplug the connector under the IAC I unplugged the connector to the left going into the throttle body.
The IACV and ECT sensor seem fine. When the idle is acting up (high or fluctuating idle), remove the air intake system and then cover the hole inside the throttle body leading to the IACV. Does the idle speed drop and steady?
I will have to wait to get it to act up I am about to go out for a drive to see if I can because I couldn't get it to while idling in my garage I will update soon. Thanks Ron!
