Transmission leak question & picture
This leak started one week after having a used transmission put in. On the transmission it states PLW on the left side, SLW right behind the rad fans.
To me this looks like a m/t fluid fill plug but doesn't look like all the DIY pictures I see. Car is a 2001 Civic EX w/ 133,000 miles. The "new" used tranny had less than 75,000 miles on it and feels fine.
What is this part?
Can I tighten it?
Does it have a seal?
Thanks!
What is this part?
Can I tighten it?
Thanks!
Yeah, it's the fill plug. Threads should be coated. Try tightening it A LITTLE. If that doesn't solve it buy a new one. It's number 10: http://www.hondapartscheap.com/index...MISSION%20CASE
that is NOT a fill plug!! that's a plug likely to access the snap ring for one of the shafts inside the trans.
a m/t fill plug has a 17mm head and an aluminum washer seal. so yes, you can tighten that. if it still leaks, you may have to remove it and put a bit of silicone sealant on the threads and re-install, there is also a torque spec for that which you may want to follow (steel plug in an aluminum housing)
donnieb22000
18
Jun 26, 2018 10:20 PM
Andrew14
21
Jun 28, 2010 01:12 PM
VtecAdvantage
Mar 30, 2010 10:10 PM
