B16 idle question
i have a stock b16 and when the car warms up and im not running the a/c the idle surges from 1000 to 1700 rpm but when i put the a/c on the idle returns to 800. i dont know what could be causing this. if its a sensor or a clogged valve. but i just wanna get ti fixed so that my car doesnt get hotter than it should before my road trip in a couple weeks
idk i bought it already tuned its got 2-step thats all i know, and it idles around 800rpms when cold with or without a/c but only when cold. and no it doesnt bog down when the a/c kicks in when the motor is cold. but when the motor is at running temp the a/c calms the surge
800 rpms seems pretty low for a cold engine warming up. I think the FITV put's it around 1250rpms or so. Check to see if your leaking any coolant from the feed or return hoses on the FITV.
If the idle surge is happening when your engine is warm, it's your IAC. Test it for resistance.
