S1 tranny, can i use a VSS insted of the cable speedo?
hi guys,
i have a s1 tranny that i want to swap in my obd1 89 wagon.
is there a vss that will fit insted of the cable gear drive?
thanks
thanks
S = Speed
S = Sensor
what exactly are you trying to swap? if your wanting to go from a cable operated speedometer to an ELECTRIC speedometer, then you can get one from any 92-00 civic or 94-01 integra. they will work. in not positive of newer years or if the F and H series VSS will work. but with doing this you will also need to convert over to a newer gauge cluster, or a JDM cluster. because by eliminating the speedometer cable you will have no way of displaying your vehicle speed on your dashboard.
dannyb18c
May 11, 2012 02:04 PM
rewerbcrx
Jul 19, 2007 04:28 PM
wickedEFguy
Dec 16, 2002 03:51 PM
