Replacing oxygen sensor
Old Oct 30, 2011 | 04:48 PM
4everYoungCRX's Avatar
Default Replacing oxygen sensor
Does anyone know where the o2 sensor is in a 91 CRX? I'm trying to replace it myself. Does any one have any tips or directions to changing it? Thanks
Old Oct 30, 2011 | 04:53 PM
singlecamsaint's Avatar
Default Re: Replacing oxygen sensor
it should be visible if you look down between the radiator and the front of the engine, itll be sticking in the side of the down pipe down there. itll have one wire running to it considering its a stock car.
Old Oct 30, 2011 | 04:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It's on the exhaust manifold before the "A" pipe. (As long as it's not a HF model...)
Tips - use a oxygen sensor socket, PB Blaster, and some heat if you have to. This is probably one of the easiest things to do - lefty loosey, righty tighty... but since you are asking where it is I already have an extremely bad feeling about this.
Old Oct 30, 2011 | 05:06 PM
agreed it will be in there tight more than likely
Old Nov 24, 2011 | 02:26 PM
thanks all. i got it replaced using a o2 socket. very straight forward.
mrwokn
Mar 20, 2011 08:44 AM
b18cisbetter
Jun 15, 2008 11:05 PM
Bobby01
Sep 4, 2007 06:04 PM
Kusai.Nihonjin.Desu
Nov 22, 2003 08:10 AM
CivicBoi
Mar 30, 2002 12:07 PM
