97 Integra Turbo Coolant Leak Hose Resvior
Old Oct 30, 2011 | 09:36 AM
TurboTeg332's Avatar
Icon2 97 Integra Turbo Coolant Leak Hose Resvior
Got a 97 turbo integra running 11 lbs. I have a stock 97 civic radiator on my car also. Ive never had problem with it holding coolant until the last 4 or 5 months. I keep leakin coolant from where the resvior hose connects to the radiator and im not sure why its doin this. I put a hose clamp over it and coolant still leaks from line whenever coolant is tryin to go into the resvior tank.
Every time i drive it just about i have to put more coolant in it bc its not up to level of top of tank.
I have also noticed that it whenever the car is up to normal operatin temp and it vents coolant to the overflow tank but whenever car cools down the radiator will not suck the coolant in the resvior back up into radiator.
Ive done compression test and leak down test and everythin looked good.
Ive never seen where a car can leak coolant from where overfow hose connects to the radiator.
Anyone have any ideas bc at this point the only thing i can leak of is my head gasket may be startin to go and mayb im gettn compression into water jacket.
ANy ideas anyone?
Old Oct 30, 2011 | 11:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: 97 Integra Turbo Coolant Leak Hose Resvior
Check hose for blockage, replace rad cap. 94
Old Oct 30, 2011 | 11:47 AM
racebum's Avatar
sounds like a bad cap. replace the rad cap and see what you get
compression in the water is the other possible but try the cap first.
prodjay10
Honda Civic (2001 - 2005)
May 27, 2015 09:23 AM
cc203
Jan 17, 2012 12:21 PM
raju687
Sep 16, 2011 05:42 PM
hondalove888
Jun 9, 2008 06:22 PM
honda_coupe
Jan 24, 2006 03:10 PM
