Rescaling map for new MAP sensor without retune? Neptune
I have a 10.1psi spring in my wastegate currently and since its been colder lately, I've been hitting boost cut (stock MAP sensor). I'm planning on buying a new one that reads higher, and was wondering if the map can just be rescaled without re-tuning the car. My tuner is 6 hours away so I was hoping he could rescale it and send me the new map that I'll just burn to a chip.
Thanks!
Thanks!
It matters how close the map scaling is and how close the map sensors are. If you are going to a 3 bar, you will need to retune. 2.5 and 4 bars are not that far off. You should retune (at least check it).
