Oil leak from head gasket near oil dipstick?
i have a b18c1 in a 94 sol and i seem to have oil leaking form the head gasket right above the dip stick is this normal?ill get a pic or 2 in a min
still runs fine but if i push on it i can smell oil,it only seems to be around the dipstick no where else.If it is the gasket with where its leaking would that mean the head is warped?then would it be easier to replace the gasket or should i swap in the ls/v i have sitting?sorry for the noob questions but its my 1st honda and its diff. than the camaro's im used to working on
had it checked out in a local shop that did clutch and flywheel for me they said the rear main and the shitty tap in the oil pan were the only leaks and i had them replace the rear main i did the cam seal and valve cover gasket myself and i could tell it was the valve cover gasket but now its leaking lower where i cant see with the header in the way.Header is new so im not sure if it was leaking b4 or not couldnt see that part of the block with the stock mani and heat shield there.Now that its cold out i cant drive it without smelling the oil burnin.guess i need to know if it is the head gasket would that mean that something is warped and if i swap the c1 for the ls/v do i need to change anything?
and you'd generally have other symptoms. Are you losing coolant?
was told when i bought it exactly what u said previous owner overtorqued the bolt in that stud and broke it.guess the semi built ls/v is going in and i dont know how i never noticed the crack.thanks for all the help everyone,kept me from chasing something that never would have fixed the leak
redacura
Feb 17, 2019 05:34 PM
