transmission/clutch problem, need help!
Old Oct 29, 2011 | 10:28 AM
Devers's Avatar
Default transmission/clutch problem, need help!
Wrong section I know. I'm looking for fast answers, sorry.
YEAR: 1998 MAKE: Honda MODEL:Civic EX 4DR ENGINE: B18C1 (GSR) TRANNY: GSR Tranny Clutch: ACT stage 1 clutch Type R flywheel Heavy duty pressure plate New Clutch cylinder 2 months old New slave cylinder 2 months old New throw out bearing 2 months old
Ok, so here's the deal. Last night I'm driving. I believe in 4th gear at 3k rpms when suddenly I hear a loud noise, sounded like something fell and started dragging, so I pull over and go to put the car in neutral, let go of the pedal and the car stalls. So i then look under the car for any leaking fluid or anything that might have fallen off. There's nothing on the ground, so I get back in the car, foot on the clutch, I turn the car on. Put it in 1st, give it gas to take off, but car doesn't move, once i take my foot off the clutch the car stalls whether I'm giving it gas or it being in neutral. Had to get towed home, and while being towed it was very noisy kind of like there was "stuff spinning inside the transmission?" I'm not sure what the problem could be, if anyone could help me out. It would be much appreciated.
Thanks in advance,
Mike.
Old Oct 29, 2011 | 10:54 AM
Quik Chris's Avatar
Default Re: transmission/clutch problem, need help!
Pull the tranny and look at the pressure plate and disc, if they're not bad, it's in the tranny.
Old Oct 31, 2011 | 02:46 AM
__oversea's Avatar
I thought ITR flywheel and GSR flywheel is not interchangeable.
Old Oct 31, 2011 | 02:55 AM
Dioxine's Avatar
Yep, since the clutch engages and disengages im gonna lean toward your tranny is gone
Old Oct 31, 2011 | 10:59 AM
Hidenplanvew's Avatar
could be that the pressure plate failed or the springs inside the clutch failed
Old Oct 31, 2011 | 04:55 PM
Dioxine's Avatar
Would a failed pressure plate cause stalling in every gear? I wouldnt think so but then again im not completely sure.
Devers
Transmission & Drivetrain
Nov 10, 2011 08:42 PM
JDM3STAGEVTEC
Dec 19, 2008 07:43 PM
elnoyl
Nov 5, 2006 07:55 PM
TaylorEj1
Apr 2, 2006 02:25 PM
jonoknut
Dec 26, 2002 11:56 AM
