ITR suspension on an EF...
will my stock springs and shocks fit my EF??? bout to upgrade the ITR and will be pulling the stock springs and shocks and since there just going to be sitting around thought about putting it on the hatch if they'll fit... shocks at least cause mine are about 11 years old
did a search and found were someone says it might fit 89-91's, but does anyone know for sure and are there any mods i have to make to get them to fit???
Hell give it a shot and let us know!
btw: you can't use the rear lower control arms on your crx with the rear shocks from your ITR... The only way you could do this is if you have a 1988 si.. and it must be a crx. Only the 88crx si had rear lca's like that of the ITR.
You need the 88 Civic/CRX rear LCAs, and you need the 92-up Civic or 94-up Integra front shock forks, as the ITR shock (as well as the above mentioned Civics and Integras) are larger diameter than the 88-91 Civics and 90-93 Integras.
How much does ride height get messed up with ITR sized shocks/springs? I heard there was a couple inches worth of difference.
I wonder why people mess with newer style.....
Anyway,a guy from here as put 99-00 Si shocks and coil on his 4 gen Zizic.
The car looked like a Baja style truck.
I prefer my Koni and H&R made for my 4 gen.
Hope it is going to work for you!
hondaluver12
Aug 29, 2009 02:21 PM
