civic ef 90 need some help
Old Oct 28, 2011 | 01:35 PM
mandob20b's Avatar
Default civic ef 90 need some help
sup guys im some new on hondas so i need some help first i got a b20b with b16 head turbo sotck bottom end stg1 turbo web cams 450cc injectors 255walbro pump xs power turbo at 10psi and jdm pw0 ecu. no dyno and cause of that my 2 pistons are gone and 2 sleeves also what do u guys recomend me 2 buy like pistons if should i stay with my original obd 0 wiring harness or change it to obd1
Old Oct 28, 2011 | 02:17 PM
Nathan_volcom's Avatar
Default Re: civic ef 90 need some help
Buy an ls.... better walls for turbo. and convert to obd1 Wayyyy more tuning capabilities. conversion harnesses are pretty cheap.
Old Oct 28, 2011 | 03:14 PM
crx_si-r's Avatar
get it tuned before you smash out on it. i recommend obd1 upgrade
Old Oct 28, 2011 | 03:15 PM
mandob20b's Avatar
on the upgrade u ment by the entire harness or just the jumper harness
Old Oct 28, 2011 | 04:07 PM
crx_si-r's Avatar
that would be up to you. i build full complete harnesses, but you can also use a jumper and then do the rest of the upgrades
motoguy126
Jul 26, 2010 09:43 PM
90civic_hatch
Jun 9, 2009 08:19 AM
HtC_SiR
May 26, 2004 12:11 PM
mugenintegra16
Apr 8, 2004 10:26 PM
SpeedMonkeyRacing
Jun 8, 2003 10:49 AM
