93 lude headlight problem.. HELP
so out of no where my headlights stopped working.. all other lights turn on with switch ( tails, bumpers, dash) but headlights wont. ive replaced relays, bulbs, checked fuses, grounds and replaced light switch and still nothing!! any help is appreciated im kinda stuck and out of ideas
thanks in advance
thanks in advance
Both lights at once? That is a bit odd, but I would get out a multimeter, and start checking your wiring for power, and trace back until you find power. maybe you have a wire in the harness that got corroded or cut?
Did you use a multimeter to measure continuity at the bulb connectors to see if there's ground or power? I'm looking at the wiring diagram right now on All Data, and all I can think of is check your ground points and fuses.
It could be the harness needs to be replaced. As suggested above, use a multimeter to check for power at different places, starting from where you insert the headlight bulbs and working your way back.
DoubleEx
Apr 7, 2010 01:13 PM
Rhymenoceros
Apr 22, 2007 07:23 PM
JDM_d15b_eg8
Jun 25, 2006 02:16 PM
