D16 Built to BOOST Parts List
Put the Sol in the Garage Yesterday and am begining to order parts for my turbo build. This car is going to be being built over the next 4 months and along w/ a "full engine build" it is also getting misc. body work (small dents and light rust repair) fixed.
Below is "my parts list"
Any input would be appreciated why or why not to use something vice versa.
D16 Built To BOOST Project SOLREAPER
Block:
Hot Tanked - Decked - Honed
Block Guard
75mm Vitara Pistons
Forged I-beam Rods
ACL Bearings (Main,Rod,Thrust Washers)
OEM Timing Belt
OEM Water Pump
FULL OEM Gasket Set (Stock or Cometic.030mm Headgasket)
Notched Sleeves and Journals
Head:
Skunk Pro2 Intake Manifold
Valve Job
ARP Head Studs(P# - 203-4301)
Supertech Valves, Springs, and Retainers
Catch Can between Intake and PCV
Zex Turbo Cam (P# 59300)
Turbo Parts List:
.57 Trim 55 A/r Greddy or Turbonetics or w/e turbo Nothing ebay
Log Style Manifold
2.5” Downpipe
38mm Wastegate (dumptube)
Tial BOV
Oil Feed/Return Kit
Charge Piping
Intercooler
Couplers and Tbolt Clamps
Fuel:
Walbro 255 Fuel Pump (OEM Filter Screen)
DSM Black Top 450 Injectors
Misc:
New Clutch and Flywheel
Street Tuned on Crome to drive to Get Dyno Tuned
High Flow Cat
OEM Oil Pump
S2k Oil Filter
Again any input/ideas would be appreciated (Yes i have searched, yes i have googled. This is MY build list All im really interested in is why X wouldn't work with X and why)
Block:
Block Guard
75mm Vitara Pistons
Forged I-beam Rods
OEM Timing Belt
OEM Water Pump
Head:
Valve Job
Turbo Parts List:
Log Style Manifold
2.5” Downpipe
Tial BOV
Oil Feed/Return Kit
Charge Piping
Intercooler
Fuel:
Misc:
High Flow Cat
OEM Oil Pump
S2k Oil Filter
Block.
Many will tell you to overbore to 75.5 to insure the cylinder walls are truly in round and to avoid the dreaded piston slap.
Depending on the rods the block may or may not have to be notched.
I don't think ACL is in business any more. You'll probbly wind up getting King bearing instead.
Head.
Looks fine.
Someone may beg to differ.
Turbo.
Where's the turbo?
You can't do anything without it.
Fuel.
I can see you're not going for big power.
If you're building the block you should leave room in those injectors for more boost later.
Maybe get some 750cc.
Oil pump.
Which engine?
If it's a Y8 I'd get a port and shimmed pump OR possibly a Z6 crank.
The S2K oil filter will help out with additional oil pressure.
Clutch. Get a clutch that will hold the power you're going to put down. All this stage 1 stage 2 stuff is totally arbitrary.
Some of your parts are pretty generic.
I would go with Hondata or Neptune for the EMS. And a real dyno tune. The physical installing of the parts is a small part of a turbo build in my opinion. The real magic is in the tune. I also see nothing listed for monitoring your engine like gauges or a wideband.
This will probably be moved into the Forced Induction forum where better people with more experience than me and my entry level system can give better advice.
Head.
Looks fine.
Turbo.
Where's the turbo?
Fuel.
Oil pump.
Which engine?
Block.
Many will tell you to overbore to 75.5 to insure the cylinder walls are truly in round and to avoid the dreaded piston slap. Thanks for the info
Head.
Looks fine.
Turbo.
Turbo will by a 57trim .55A/R some kinda Greddy/Turbonetics
Where's the turbo?
You can do anything without it.
Fuel.
Oil pump.
Which engine?d16z6 sorry for that
Also I would be concerned because you list NO engine management whatsoever.I have under misc. that it will be street tuned on Chrome, to be driven to be Dyno Tuned on most likely HondataS300 The physical installing of the parts is a small part of a turbo build in my opinion. The real magic is in the tune. I also see nothing listed for monitoring your engine like gauges or a wideband.
There will be misc gauges A/F Gauges, EGT, Psi, and most likely a Oil Psi Gauge didn't think these were important to list as a part of the BUILD
Understandable and thank you for your input!
Head.
Looks fine.
Turbo.
Where's the turbo?
Fuel.
Oil pump.
Block:
Block Guard
75mm Vitara Pistons
Forged I-beam Rods Are you going with FJR? You have to wait a while for the groupbuy...
ACL Bearings (Main,Rod,Thrust Washers) ACL bearings generally give you looser clearances from what I read. I'd go with Clevite or Kings
OEM Timing Belt
OEM Water Pump
Notched Sleeves and Journals Don't notch your journals. You may or may not have to notch the girdle, but there is absolutely no journal notching involved.
Head:
Skunk Pro2 Intake Manifold What is your power goal? Most can be attained on a stock head, so unless you plan to rev above the stock rev limit the money put into a built head is better spent somewhere else.
Valve Job
Turbo Parts List:
Log Style Manifold - Depending on power goals, the ebay cast manifolds have been proven over and over to hold up without cracking. Ebay intercoolers and charge piping are fine as well.
2.5” Downpipe
Tial BOV
Oil Feed/Return Kit
Charge Piping
Intercooler
Fuel:
Walbro 255 Fuel Pump (OEM Filter Screen) - there is a sponsor in the marketplace selling these for $79 shipped with install kit. Cheapest price I've ever seen and he ships fast.
DSM Black Top 450 Injectors Again, depending on your power goals you may need bigger injectors.
Misc:
Street Tuned on Chrome to drive to Get Dyno Tuned If you don't boost and keep it slow a basemap will be just fine for getting to the dyno - you can get one for $30 from xenocron. You'll also need a chipped P28
High Flow Cat
OEM Oil Pump
S2k Oil Filter
Block:
Block Guard
75mm Vitara Pistons
OEM Timing Belt
OEM Water Pump
Head:
Valve Job
Turbo Parts List:
2.5” Downpipe
Tial BOV
Oil Feed/Return Kit
Charge Piping
Intercooler
Fuel:
Misc:
High Flow Cat
OEM Oil Pump
S2k Oil Filter
Also they sell a teflon coated true 75mm Vitara that supposedly doesn't piston slap on a stock bore...I'd research more on that if I were you - check out d-series.org for a ton of more information.
Thanks for the info!
https://honda-tech.com/forums/appearance-build-threads-122/1997-civic-ex-sedan-2969915/
The turbo stuff is about halfway down the page
Here's the $79 shipped Walboro with install kit
https://honda-tech.com/forums/forced-induction-49/walbro-pump-w-kit-79-shipped-rc-injectors-2819191/
Again, what are your power goals?
You should look at the single cam thread in the FI forum. Pages and pages of builds.
BTW. I saw where you listed CROME as the software. I know it's free but if I read this correctly, it's no longer being developed. I wouldn't want to run my engine on old and discontinued software. I had my car intially tuned on it and immediately afterwards found this out. I have a full Neptune RTP sitting here in a P28 waiting to go in.
Also, Ebay builds have been proven to be hit or miss.
As for coated teflon pistons that's good news BUT I would still have the shop check the cylinders to see if they might be out of round.
https://honda-tech.com/forums/showthread.php?t=2819191
Thanks for the link as well
+1 on checking the cylinders - lots of people on d-series.org throw in pistons and get away with it, but the only way to be sure is to check them.
DSM injectors will be fine then. There's a guy on here that sells freshly cleaned and flowed injectors for $120 shipped, I got mine through him and they've worked great. You need a resistor box - any accord at the junkyard should have one.
For your power goals, an Ebay cast manifold would work just fine. However if you want the bling then by all means go for the fancier ones. I would get a Tial wastegate if I were you, I'm using a $25 ebay special and it's held up but these are hit and miss.
Like Grumblemarc said, now's the time to start reading build thread after build thread and see what people run before buying anything.
I said Ebay building meaning some parts are from Ebay. I wouldn't recommend using an Ebay turbo as those are hit-and-miss, and definitely don't use feed/drain lines that are really cheap from Ebay.
As far as Crome - I'm tuned on Crome Gold and it's fine - however a reputable tuner around here blew up my friend's B16 due to Crome and switched to Neptune immediately. I heard Neptune is a lot better but Crome still works. I paid $150 for a street tune on Crome which I would NOT recommend - I'm surprised it's lasted so long. Get a GOOD dyno tune and you won't regret it!
This is the link to the single cam boost thread.
https://honda-tech.com/forums/forced-induction-16/sohc-boosted-set-ups-chime-place-single-slams-1643764/
Venting should strongly be considered. Even at a mere 6 PSI on a Greddy 15g I was getting oil forced through the PCV valve. It has been said that it isn't needed for low boost applications but I would beg to differ on the side of caution.
I recently installed a modified oil cap that has a breather element in it and it's made a hell of a difference.
pretty sure the piston slapping days are over. because back then they had suzuki spec pistons which were a hair smaller in size then the honda spec. now they have true d16 vitaras just have to make sure you get them. and they are supposedly teflon coated, id assume that would wear out pretty quickly though. ive seen many 75mm vitara build with no slap that ran great. also have to run the piston arrow towards flywheel i beileve
but the best thing to do is 75.5
acl is still around... they run tighter, so you will have to get the crank micro polished. King bearings work too but you still have to get the crank micro polished. Run FJ rods so you ended up with like 8.5 compression.. eagle, manley, and other rod companys will only give you something like 7.5 compression (yes it makes a diffrence). If you can pick up a set of 1000cc injectors. You can get away with 75.5 but if you go to 82 mm you need to get the bock sleeved. Go with a Delta regrind heard bad things about the zex cams having alot of issues.
I made 440 on stock block and vitaras, eagle rods, 1000cc injectors, hx35 and cast manifold
ACL still around? I keep hearing stories where people are ordering ACL bearings (usually in a kit) and are getting King bearing instead. Abut how there seems to be some problems contacting them and even placing and new orders.
nothing wrong with king bearings. all you noobs think because they say race they must give me more power
Where did anyone say there was something wrong with King bearings? I know I didn't. I love how reading comprehension is still taught in schools.
slick1851
May 29, 2010 10:48 AM
victor.ek4
28
Aug 2, 2009 02:43 PM
chocolatesk8er10
Appearance Build Threads
Sep 10, 2008 09:48 PM
