Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
500+whp 07 Civic SI build (final round of upgrades)
Old Oct 28, 2011 | 06:33 AM
wildabeast's Avatar
Default 500+whp 07 Civic SI build (final round of upgrades)
This is my final round of upgrades. And I figured I'd do it all, and do it right for what I want to do. DD fast spooling highway driver (sleeperish).
1st round upgrade: 350whp.
2nd round upgrade: 440whp, 312wtq.
Old thread https://honda-tech.com/forums/honda-civic-2006-2015-79/2007-si-350whp-build-2697997/
440whp video:
http://www.youtube.com/watch?v=8at7I_lc7Ak
This build has been going on for a while, but it's coming to an end in about 2 weeks when I pick it up and sit in for the dyno tune (Nov 12th-ish)
here's my list:
SRT v2 turbo kit w/ the following:
vband T3 precision 6262 billet turbo .64 a/r velocity stacked
4" Intake
vband tial qbov
vband tial 44mm Wastegate
3" Downpipe mandrel bent
3" Intercooler core (good for 650hp)
2.5" Intercooler piping
Tubular manifold (equal length)
3" dual resonated SRT exhaust w/Vibrant muffler and 4" tip mandrel bent
skunk2 72mm DBW Throttle body (anodized black)
Skunk2 carbon composite Fuel rail
1000cc SRT modified Bosch injectors flowtested at 950cc
Aeromotive A1000 FPR
Aeromotive 12301 10 micron filter
2x walbro 255lph fuel pumps
SRT CNC billet dual fuel hanger
-8an fuel feed SS braided
-6an return SS braided
NGK 9 spark plugs gapped to ".020
Kelford KEL-179-T1 Stage 1 Turbo cams
Hybrid Racing chain Tensioner
Pauter Rods
Arias Pistons 86.5mm w/Swaintech skirts coated and w/ upgraded pins 10:1 comp
Hondata intake manifold gasket
Hondata Flashpro
supertech valves
supertech dual springs
supertech titanium seats and retainers
supertech block guard
viton valve seals
DEI Titanium t3 turbo blanket
DEI Titanium 2"x50' wrap (manifold and downpipe)
-10an tapped oil pan return
Hondata Boost solenoid (BBG)
AEM TruBoost Boost controller (used as boost gauge)
AEM Wideband
Xelerate dual gauge pod
Machine work:
bore .5mm over (essentially to get rid of imperfections)
port match intake manifold inlet to throttlebody (+12mm difference)
MAin/rod bearing tolerance check and balancing (ACL rod & main bearings install if needed)
Vacuum block
DIY Venom oil catch can
HFP Underbody kit
HFP suspension
Silver dash highlights
new OEM headgasket
k20a2 oil pump (no balancing shafts vs k20z3 oil pump)
custom baffled oil pan (customizing at shop)
front main seal (crankshaft)
rear main seal (crankshaft)
low temp thermostat
ARP head studs
Albins 1-4 Gears
Acura TSX 5th gear
Synchrotec carbon Synchros 1-6 Gears
I'll add photos and videos in the coming weeks. Just havent had a lot of time and work has been hammering me.
Technically, from everything I've seen others do: This build should net me around 550whp on 93 octane on around 16-19lbs of boost and 600+whp on c16 @25lbs of boost
Old Oct 28, 2011 | 06:34 AM
wildabeast's Avatar
Default Re: 500+whp 07 Civic SI build (final round of upgrades)
Reserved for Pics.
tsx 5th gear, rsx oil pump, oil pump sprocket, synchrotech carbon synchros
1/2 3/4 synchro sleeves
I also decided I'd make myself a "real" catch can. Go DIY!
Stage 5 clutch and new TOB installed
Yep, car is being dropped off at SRT in Maryland to do the build.
Old Oct 28, 2011 | 03:07 PM
97emsedan's Avatar
that is a really nice finish to a long hard project... nice job...
Old Nov 5, 2011 | 09:47 AM
PSU's Avatar
PSU
formerly DxHatchback
Looks pretty dang stout!
Old Nov 6, 2011 | 01:43 AM
ryangold's Avatar
I'm jealous.
Old Nov 7, 2011 | 09:25 AM
Gearspeed-Performance's Avatar
Looking good!
Old Nov 10, 2011 | 09:44 AM
Mr-Sleeper-34's Avatar
Nice build. Is your exhaust side really 3", or did you have to transition from 2.5" for the DP?
Old Nov 11, 2011 | 06:56 PM
Greg50Lt's Avatar
Sounds like the car is going to be really well built. I might have missed it but what type of racing do you plan to do with the car? Or is it going to be a fast DD?
SRT is relatively close to my house. Ive heard some good things about them but I've heard more bad then good. Not knocking your progress or your them as Ive never dealt with them personally, Ive just been told to keep my distance.
Old Nov 12, 2011 | 01:00 AM
jjx19's Avatar
Damn!!
Old Nov 17, 2011 | 07:05 PM
jaepalm's Avatar
DD greg!
Old Nov 30, 2011 | 02:38 PM
wildabeast's Avatar
:-D
Final numbers were actually 552whp/388wtq @20lbs
Old Dec 1, 2011 | 10:20 AM
wildabeast's Avatar
Old Jan 17, 2012 | 10:19 AM
El chico's Avatar
keep up the good work dude!
Old Feb 14, 2012 | 09:01 AM
wildabeast's Avatar
I might be designing my own cams because I'm not all that impressed with the kelfords turbo cams. I think I can do better with cam design. The idle isnt great (-14psi at best, and -7.9psi at worst with waterpump/thermostat and a/c on) because of the amount of overlap there is on the low cam on top of my already much larger TB. The high cam definitely makes power, but my vtec comes in fairly soon, so I think there should be less overlap on the low lobe because of how the vtec point is.
Old Aug 23, 2012 | 03:03 PM
Honda 809's Avatar
Nice Build
bburtonsk8r2
Feb 26, 2008 04:16 PM
Chee_dog
Jun 30, 2007 10:29 PM
altz
Feb 26, 2006 08:00 PM
Phil@SFP.net
Jan 10, 2005 05:22 AM
Tinker219
Aug 31, 2004 06:50 AM
