pedal bracket broke today, need sum info
so i get in my car after work ,push in the clutch and i hear a big snap! the side of my pedal bracket where my clutch is broke off the side rod. I welded it back on for now but its leaning to the side and is not grabing the cable properly. After work tmrw ill head to the junkyard to pick one up.I need any advice or special guide on doing this the right way cus i have no clue. Thanks!
i did that! but its damaged to much..the clutch pedal lean's to the side and isn't aligning with the start button that allows me to start up.So every time i need to start up i need to go under the dash to press on the button lol
oh shiit i didnt have that problem ..fuuuk well i guess ur gonna have to get a whole another assembly ..hit up pick a part in el monte off of peck always a few ef's there .ay btw off topic but who installed ur rear fog cuz i got mine and i wanna put it on already ..also what up with them zc headlights lol ?shoot em this way
i installed my rear fog, used a plasma cutter to cut thru the rear bumper support . Lol and the zc headlights are staying my way!! shoot the hood over this way" let's get back on topic now.I'm
doing research and seen that i will need to drop my steering colum?wtf? if any has done this please let me know
lol aight but yeah u have to take out driver seat to be comfortable than drop the colum than un bolt i think its 8 bolts in total to take out the pedal assembly than put it all back with the new assembly two people will be good to help u out
If you do have help its just as easy to pull the dash and not have to worry about laying upside and hard floor on your back, gl though its fun hah
Happened to me too
Welded it but it was also leaning a little
And broke again
Got a whole new one at junkyard
Just make sure u get the same one as urs
Cuz I got one without the neutral safety switch
Under the clutch
And had to go back for another one
But it's easy to change
Pulling the seat would be good cuz u need alot of room
I dropped the steering column
Left the dash in
And there's alot of bolts to take off pedals
But it's easy good luck
And broke again
Under the clutch
Left the dash in
so i hit the junk yard and pulled one off a dx,wasn't to hard.But its not the same as my si, but i figured i can mod the switch..it will still bolt up without a problem right? ill be installing it Sunday
if it is from an 88, it won't have the clutch safety switch.
Si has a different spring compared to other trim models. Apparently it doesn't really do anything special, so one from a CX, DX, EX, LX will work.
goosane
Jul 23, 2007 07:31 AM
JDM_rolex
Jun 11, 2007 07:58 PM
[626]95-GSR
11
Mar 29, 2003 09:13 PM
[626]95-GSR
Mar 27, 2003 10:49 PM
