will the 96-00 civic front lca's fit onto the 92-95 civics?
I want to know if the front lca from 96-00 civic will fit onto the 92-95 civic? Im not trying to run sway bars or anything, just need new bushings because mines are shot. Most of the 92-95 civic front lca i find have ripped bushings but the newer 96+ civic i find have good bushings. The part numbers are a little different but they look almost identicle in pictures. anyone here know if it will fit??
The bushings are a different inner diameter where it bolts to the subframe. They are not bolt-in interchangeable.
You can do it, but it would be cheaper and easier to press new bushings into your EG arms.
Just get bushings, I might have a kit I can sell you although it might have more then just those bushings in it. Either way new bushings will improve the handling and long term wear life.
jdmcivic2fast
Oct 27, 2011 05:32 PM
godluvstegs
May 6, 2011 12:40 PM
chris_c
12
Dec 10, 2004 12:29 PM
MarkZeroNine
Nov 2, 2003 08:24 AM
