will 96-00 civic front lca fit onto 92-95 civic??
Old Oct 27, 2011 | 03:56 PM
jdmcivic2fast's Avatar
Default will 96-00 civic front lca fit onto 92-95 civic??
I want to know if the front lca from 96-00 civic will fit onto the 92-95 civic? Im not trying to run sway bars or anything, just need new bushings because mines are shot. Most of the 92-95 civic front lca i find have ripped bushings but the newer 96+ civic i find have good bushings. The part numbers are a little different but they look almost identicle in pictures. anyone here know if it will fit??
Old Oct 27, 2011 | 04:04 PM
98civdx's Avatar
Master Detailer
Default Re: will 96-00 civic front lca fit onto 92-95 civic??
Nope. Not without swapping the subframe, and a few other things.
Old Oct 27, 2011 | 04:19 PM
I know theres 2 parts to the front LCA, I just need the arm that has the 2 bushings, will it work?
Old Oct 27, 2011 | 05:32 PM
98civdx's Avatar
Master Detailer
No, that is the part of the problem. The reason why it wont, is the bolt sizes are different. IMO, EK 12mm, EG/EG 14mm.
It will bolt in, but not correctly, and it wont be safe to drive.
jdmcivic2fast
Suspension & Brakes
Nov 18, 2011 09:58 AM
PatrickFrantz
Jul 25, 2008 12:57 PM
sluggishEG
Suspension & Brakes
16
Feb 27, 2007 05:28 PM
chris_c
12
Dec 10, 2004 12:29 PM
